Where to register server starting with mqtt:// instead of tcp://
Hello,
I am in early testing of ignition. I am using MQTT Explorer to publish. MQTT Explorer generates urls starting with mqtt://. I have installed MQTT Engine, Distributor and Transmission. So far I have only found options to enter server addresses starting with tcp:// or ssl://
any help would be much appreciated.
The hostname is the important part, isn't it?
Just copy everything after mqtt:// and put it into one of the tcp:// or ssl:// addresses.
Hello Kevin, thank you very much for the quick reply. You are right, it was that easy:)
