an architectural question:
i built several similar projects, and each of them takes data from a his table.
then i built a component, querying with a parametrized sql tablename (i can place the same component to have different behaviour).
i need to store the DB table name somewhere visible at project level, but i’ve noticed that:
a tag has whole server scope
dynamic properties have window scope (i should repeat it for each window)
i am searching for something in intermediate level, insertable in sql queries, is it there?!
thank you
Client tags are scoped to the instance running, which is smaller than the project. In other words, a client tag on one computer can be a different value than that same tag running the same project on another computer. That may be what you’re looking for building dynamic SQL queries on a client based on user input.
