Why can I not create a new Perspective Project via Designer?
I've tried three times, just to make sure, to create a new project via the Designer Launcher. I get this error:
java.util.concurrent.ExecutionException: java.io.IOException: HTTP response code: 403
	at java.base/java.util.concurrent.FutureTask.report(Unknown Source)
	at java.base/java.util.concurrent.FutureTask.get(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.get(Unknown Source)
	at com.inductiveautomation.ignition.designer.ProjectDialog$4.done(ProjectDialog.java:402)
	at java.desktop/javax.swing.SwingWorker$5.run(Unknown Source)
	at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.run(Unknown Source)
	at java.desktop/sun.swing.AccumulativeRunnable.run(Unknown Source)
	at java.desktop/javax.swing.SwingWorker$DoSubmitAccumulativeRunnable.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.Timer.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.Timer$DoPostEvent.run(Unknown Source)
	at java.base/java.security.AccessController.doPrivileged(Unknown Source)
	at java.desktop/java.awt.WaitDispatchSupport$2.run(Unknown Source)
	at java.desktop/java.awt.WaitDispatchSupport$4.run(Unknown Source)
	at java.desktop/java.awt.WaitDispatchSupport.enter(Unknown Source)
	at java.desktop/java.awt.Dialog.show(Unknown Source)
	at java.desktop/java.awt.Component.show(Unknown Source)
	at java.desktop/java.awt.Component.setVisible(Unknown Source)
	at java.desktop/java.awt.Window.setVisible(Unknown Source)
	at java.desktop/java.awt.Dialog.setVisible(Unknown Source)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.openProject(IgnitionDesigner.java:489)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.startup(IgnitionDesigner.java:472)
	at com.inductiveautomation.ignition.designer.DesignerStartupHook.lambda$startup$0(DesignerStartupHook.java:351)
Caused by: java.io.IOException: HTTP response code: 403
	at com.inductiveautomation.ignition.designer.ProjectDialog.fetch(ProjectDialog.java:663)
	at com.inductiveautomation.ignition.designer.ProjectDialog.exampleProjectChosen(ProjectDialog.java:428)
	at com.inductiveautomation.ignition.designer.ProjectDialog$4.doInBackground(ProjectDialog.java:312)
	at com.inductiveautomation.ignition.designer.ProjectDialog$4.doInBackground(ProjectDialog.java:294)
	at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
	at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Ignition v8.1.42 (b2024061810)
Java: Azul Systems, Inc. 17.0.11
Here is what I did:
I have created several projects before and never seen this until yesterday.
EDIT:
So, I created a project via the Gateway, on the developer license. I made a few views, which I can see in the browser, but when I attempt to run a Named Query, I get this:
EDIT 2:
I restarted the Designer and got the query to work, but still cannot create a project in the Launcher.
The 403 sounds like the same underlying problem reported in this other thread:
Can you download the individual project templates listed in the JSON response from that site in your web browser?
I posted a question in that thread on how to download and use the templates.
I have the same error when trying to create a new perspective project on both MAC OS and windows 11.
How do we fix this? is this a bug on latest?
Infrastructure problem. Go read the other topic.
