I open Ignition Designer and only see the Vision module, why? I can only use Perspective in Trial mode, but it should still appear there.
When I start Ignition Designer, it displays this message. Is it related to my issue?
Thank you for your help!
Here is the the console diagnostics:
11:00:26.151 [Designer-Startup] ERROR designer.JXBrowserUtil - Failed to start Browser Engine with options
com.teamdev.jxbrowser.engine.EngineOptions:
autoplayEnabled: false
chromiumDir: C:\Users[USER].ignition\cache\resources\jxbrowser\7.12.1
chromiumSwitches:
diskCacheSize:
fileAccessFromFilesAllowed: false
isGpuDisabled: false
isIncognitoEnabled:false
language:en-us
passwordStore:
remoteDebugginPort: 9222
renderingMode: OFF_SCREEN
isSandboxDisabled: false
secureOriginWhitelist:
isTouchMenuEnabled: false
userAgent:
userDataDir:C:\Users[USER]~1\AppData\Local\Temp\UserData\dd593896-5bbc-4547-a9ae-c4e705b3ecd3
webSecurityDisabled: false
com.teamdev.jxbrowser.engine.ChromiumBinariesExtractionException: Failed to extract Chromium binaries into C:\Users[USER].ignition\cache\resources\jxbrowser\7.12.1
at com.teamdev.jxbrowser.internal.xz.XzExtractor.extract(XzExtractor.java:61)
at com.teamdev.jxbrowser.internal.ChromiumExtractor.lambda$extract$0(ChromiumExtractor.java:38)
at com.teamdev.jxbrowser.internal.ChromiumExtractor.extract(ChromiumExtractor.java:35)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.lambda$extractChromiumBinariesIfNecessary$20(EngineImpl.java:514)
at java.base/java.util.Optional.orElseGet(Unknown Source)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.extractChromiumBinariesIfNecessary(EngineImpl.java:512)
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:185)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:106)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.lambda$getOrCreateEngine$2(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.runResourceLockedAction(JxBrowserUtil.java:534)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:397)
at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:200)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:1951)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1181)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$loadProject$7(IgnitionDesigner.java:982)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:981)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2015)
Caused by: java.io.IOException: Cannot run program "C:\Users[USER].ignition\cache\resources\jxbrowser\7.12.1\7zr.exe": CreateProcess error=5, A hozz�f�r�s megtagadva
at java.base/java.lang.ProcessBuilder.start(Unknown Source)
at java.base/java.lang.Runtime.exec(Unknown Source)
at com.teamdev.jxbrowser.internal.xz.XZ.decompress(XZ.java:22)
at com.teamdev.jxbrowser.internal.xz.XzExtractor.extract(XzExtractor.java:56)
... 28 common frames omitted
Caused by: java.io.IOException: CreateProcess error=5, A hozz�f�r�s megtagadva
at java.base/java.lang.ProcessImpl.create(Native Method)
at java.base/java.lang.ProcessImpl.(Unknown Source)
at java.base/java.lang.ProcessImpl.start(Unknown Source)
... 34 common frames omitted
Try deleting this folder and launching the Designer again:
if that doesn't work then probably Windows Defender or some other antivirus is interfering:
Yeah the Windows Defender is disabled this program!
Thanks!
Hi, Molnar. Please see Wiki - how to post code on this forum. Use the technique when posting code or error logs. Thanks.
