Hello,
The sample rate is 5 minutes and the recent record is not current through the sql query:
thank you!
If you read the description of the analog compression algorithm, you’ll see that recording of values lags one sample behind.
Side note: don’t query the Tag Historian’s storage directly. Use Ignition’s scripting methods.
