Why is there a red squiggly under the d in def valueChanged on tag script?
I have a feeling this is going to be a really simple fix, but I've been stumped for a few days now.
Please see the photo I have attached. Ignition is telling me I have an error with the def function. I'm not sure what this error means as it does not give me any insight when I hover over the red mark all the way to the right like normal. You also cannot edit a pre defined function like the one listed, so I'm not sure why there would be an error on something you cant edit and now it wont run the tag.
Is this an error with the script in the function? Any help with this would be greatly appreciated. Thank you!
Is there actual code in the function?
Edited: to give a bit more detail.
Yes, there is. We have a tag like this for all lines in this project, so there are other lines that have this tag working (although the code is a bit different depending on the machines found on the line.)
The tag expression is equal to now() and the code pretty much looks at the lines Preventative Maintenance status and if the PM status in not selected and there is no "Green" value in the table (means check is completed) , it marks the value red meaning the check for that specific machine on this specific line was missed. A quick snap shot of the code can be found below:
My first guess is going to be an indentation error.
Screenshots are not too conducive to troubleshooting. Copy your code, including the def, if possible and post it here. Click the Preformatted Text button, then paste your code in. Then we can take a closer look for you. :slight_smile:
Ah I see. It is a very long script, over 1600* lines, however its extremely redundant. I have to post it in three* parts as I was well above the character limit when trying to post in one comment. However the code will be posted exactly as it is written.
Thank you in advance for all the help!
Lines 1-642
	#define the beginning of shift 1 and where 0(midnight) is
	a = 6
	b = a+1
	c = b+1
	d = c+1
	e = d+1
	f = e+1
	g = f+1
	h = g+1
	i = h+1
	j = i+1
	k = j+1
	l = k+1
	m = l+1
	n = m+1
	o = n+1
	p = o+1
	q = p+1
	r = q+1
	s = 0
	t = s+1
	u = t+1
	v = u+1
	w = v+1
	x = w+1
#	min1 = 30
#	part = 	system.tag.read("[.]ShiftInfo").value.getValueAt(0,1)
	timeTag = currentValue.value
#	minuteTag = system.date.getMinute
	if system.tag.read("[.]PMStatus").value == 0:
		if system.date.getHour24(timeTag) == b:
			table = system.tag.read("[.]EveryHourShift1").value
#			if table.getValueAt(0,1) =="" and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,1, "Red")
#				system.tag.write("[.]EveryHourShift1",newData1)
			if table.getValueAt(0,1) =="":
			if table.getValueAt(1,1)== "":
				newData2 = system.dataset.setValue(table, 1,1, "Red")
				system.tag.write("[.]EveryHourShift1",newData2)
			if table.getValueAt(2,1) =="":
				newData3 = system.dataset.setValue(table, 2,1, "Red")
				system.tag.write("[.]EveryHourShift1",newData3)
			if table.getValueAt(3,1) =="":
				newData4 = system.dataset.setValue(table, 3,1, "Red")
				system.tag.write("[.]EveryHourShift1",newData4)
			if table.getValueAt(4,1) =="":
				newData4 = system.dataset.setValue(table, 4,1, "Red")
			if table.getValueAt(5,1) =="":
				newData4 = system.dataset.setValue(table, 5,1, "Red")
			if table.getValueAt(6,1) =="":
				newData4 = system.dataset.setValue(table, 6,1, "Red")
			if table.getValueAt(7,1) =="":
				newData4 = system.dataset.setValue(table, 7,1, "Red")
			if table.getValueAt(8,1) =="":
				newData4 = system.dataset.setValue(table, 8,1, "Red")
#			table3 = system.tag.read("[.]EveryTwiceAnHourShift1").value
#			if minuteTag < 30:
#				if table3.getValueAt(0,1) =="":
#					system.tag.write("[.]EveryTwiceAnHourShift1",newData1)
#			else:
		elif system.date.getHour24(timeTag) == c:
#			if table.getValueAt(0,2) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,2, "Red")
#			elif table.getValueAt(0,2) =="":
#				newData1 = system.dataset.setValue(table, 0,2, "Blue")
			if table.getValueAt(0,2)== "":
			if table.getValueAt(1,2)== "":
				newData2 = system.dataset.setValue(table, 1,2, "Red")
			if table.getValueAt(2,2) =="":
				newData3 = system.dataset.setValue(table, 2,2, "Red")
			if table.getValueAt(3,2) =="":
				newData4 = system.dataset.setValue(table, 3,2, "Red")
			if table.getValueAt(4,2) =="":
				newData4 = system.dataset.setValue(table, 4,2, "Red")
			if table.getValueAt(5,2) =="":
				newData4 = system.dataset.setValue(table, 5,2, "Red")
			if table.getValueAt(6,2) =="":
				newData4 = system.dataset.setValue(table, 6,2, "Red")
			if table.getValueAt(7,2) =="":
				newData4 = system.dataset.setValue(table, 7,2, "Red")
			if table.getValueAt(8,2) =="":
				newData4 = system.dataset.setValue(table, 8,2, "Red")
			table2 = system.tag.read("[.]Every2HourShift1").value
			if table2.getValueAt(0,1) =="":
				twoData1 = system.dataset.setValue(table2, 0,1, "Red")
				system.tag.write("[.]Every2HourShift1",twoData1)
			if table2.getValueAt(1,1) =="":
				twoData1 = system.dataset.setValue(table2, 1,1, "Red")
		elif system.date.getHour24(timeTag) == d:
#			if table.getValueAt(0,3) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,3, "Red")
			if table.getValueAt(0,3) =="":
			if table.getValueAt(1,3)== "":
				newData2 = system.dataset.setValue(table, 1,3, "Red")
			if table.getValueAt(2,3) =="":
				newData3 = system.dataset.setValue(table, 2,3, "Red")
			if table.getValueAt(3,3) =="":
				newData4 = system.dataset.setValue(table, 3,3, "Red")
			if table.getValueAt(4,3) =="":
				newData4 = system.dataset.setValue(table, 4,3, "Red")
			if table.getValueAt(5,3) =="":
				newData4 = system.dataset.setValue(table, 5,3, "Red")
			if table.getValueAt(6,3) =="":
				newData4 = system.dataset.setValue(table, 6,3, "Red")
			if table.getValueAt(7,3) =="":
				newData4 = system.dataset.setValue(table, 7,3, "Red")
			if table.getValueAt(8,3) =="":
				newData4 = system.dataset.setValue(table, 8,3, "Red")
		elif system.date.getHour24(timeTag) == e:
#			if table.getValueAt(0,4) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,4, "Red")
			if table.getValueAt(0,4) =="":
			if table.getValueAt(1,4)== "":
				newData2 = system.dataset.setValue(table, 1,4, "Red")
			if table.getValueAt(2,4) =="":
				newData3 = system.dataset.setValue(table, 2,4, "Red")
			if table.getValueAt(3,4) =="":
				newData4 = system.dataset.setValue(table, 3,4, "Red")
			if table.getValueAt(4,4) =="":
				newData4 = system.dataset.setValue(table, 4,4, "Red")
			if table.getValueAt(5,4) =="":
				newData4 = system.dataset.setValue(table, 5,4, "Red")
			if table.getValueAt(6,4) =="":
				newData4 = system.dataset.setValue(table, 6,4, "Red")
			if table.getValueAt(7,4) =="":
				newData4 = system.dataset.setValue(table, 7,4, "Red")
			if table.getValueAt(8,4) =="":
				newData4 = system.dataset.setValue(table, 8,4, "Red")
			if table2.getValueAt(0,2) =="":
				twoData1 = system.dataset.setValue(table2, 0,2, "Red")
			if table2.getValueAt(1,2) =="":
				twoData1 = system.dataset.setValue(table2, 1,2, "Red")
		elif system.date.getHour24(timeTag) == f:
#			if table.getValueAt(0,5) =="" and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,5, "Red")
			if table.getValueAt(0,5) =="":
			if table.getValueAt(1,5)== "":
				newData2 = system.dataset.setValue(table, 1,5, "Red")
			if table.getValueAt(2,5) =="":
				newData3 = system.dataset.setValue(table, 2,5, "Red")
			if table.getValueAt(3,5) =="":
				newData4 = system.dataset.setValue(table, 3,5, "Red")
			if table.getValueAt(4,5) =="":
				newData4 = system.dataset.setValue(table, 4,5, "Red")
			if table.getValueAt(5,5) =="":
				newData4 = system.dataset.setValue(table, 5,5, "Red")
			if table.getValueAt(6,5) =="":
				newData4 = system.dataset.setValue(table, 6,5, "Red")
			if table.getValueAt(7,5) =="":
				newData4 = system.dataset.setValue(table, 7,5, "Red")
			if table.getValueAt(8,5) =="":
				newData4 = system.dataset.setValue(table, 8,5, "Red")
		elif system.date.getHour24(timeTag) == g:
#			if table.getValueAt(0,6) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,6, "Red")
			if table.getValueAt(0,6) =="":
			if table.getValueAt(1,6)== "":
				newData2 = system.dataset.setValue(table, 1,6, "Red")
			if table.getValueAt(2,6) =="":
				newData3 = system.dataset.setValue(table, 2,6, "Red")
			if table.getValueAt(3,6) =="":
				newData4 = system.dataset.setValue(table, 3,6, "Red")
			if table.getValueAt(4,6) =="":
				newData4 = system.dataset.setValue(table, 4,6, "Red")
			if table.getValueAt(5,6) =="":
				newData4 = system.dataset.setValue(table, 5,6, "Red")
			if table.getValueAt(6,6) =="":
				newData4 = system.dataset.setValue(table, 6,6, "Red")
			if table.getValueAt(7,6) =="":
				newData4 = system.dataset.setValue(table, 7,6, "Red")
			if table.getValueAt(8,6) =="":
				newData4 = system.dataset.setValue(table, 8,6, "Red")
			if table2.getValueAt(0,3) =="":
				twoData1 = system.dataset.setValue(table2, 0,3, "Red")
			if table2.getValueAt(1,3) =="":
				twoData1 = system.dataset.setValue(table2, 1,3, "Red")
		elif system.date.getHour24(timeTag) == h:
#			if table.getValueAt(0,7) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,7, "Red")
			if table.getValueAt(0,7) =="":
			if table.getValueAt(1,7)== "":
				newData2 = system.dataset.setValue(table, 1,7, "Red")
			if table.getValueAt(2,7) =="":
				newData3 = system.dataset.setValue(table, 2,7, "Red")
			if table.getValueAt(3,7) =="":
				newData4 = system.dataset.setValue(table, 3,7, "Red")
			if table.getValueAt(4,7) =="":
				newData4 = system.dataset.setValue(table, 4,7, "Red")
			if table.getValueAt(5,7) =="":
				newData4 = system.dataset.setValue(table, 5,7, "Red")
			if table.getValueAt(6,7) =="":
				newData4 = system.dataset.setValue(table, 6,7, "Red")
			if table.getValueAt(7,7) =="":
				newData4 = system.dataset.setValue(table, 7,7, "Red")
			if table.getValueAt(8,7) =="":
				newData4 = system.dataset.setValue(table, 8,7, "Red")
		elif system.date.getHour24(timeTag) == i:
#			if table.getValueAt(0,8) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,8, "Red")
			if table.getValueAt(0,8) =="":
			if table.getValueAt(1,8)== "":
				newData2 = system.dataset.setValue(table, 1,8, "Red")
			if table.getValueAt(2,8) =="":
				newData3 = system.dataset.setValue(table, 2,8, "Red")
			if table.getValueAt(3,8) =="":
				newData4 = system.dataset.setValue(table, 3,8, "Red")
			if table.getValueAt(4,8) =="":
				newData4 = system.dataset.setValue(table, 4,8, "Red")
			if table.getValueAt(5,8) =="":
				newData4 = system.dataset.setValue(table, 5,8, "Red")
			if table.getValueAt(6,8) =="":
				newData4 = system.dataset.setValue(table, 6,8, "Red")
			if table.getValueAt(7,8) =="":
				newData4 = system.dataset.setValue(table, 7,8, "Red")
			if table.getValueAt(8,8) =="":
				newData4 = system.dataset.setValue(table, 8,8, "Red")
			if table2.getValueAt(0,4) =="":
				twoData1 = system.dataset.setValue(table2, 0,4, "Red")
			if table2.getValueAt(1,4) =="":
				twoData1 = system.dataset.setValue(table2, 1,4, "Red")
		elif system.date.getHour24(timeTag) == j:
#			if table.getValueAt(0,9) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,9, "Red")
			if table.getValueAt(0,9) =="":
			if table.getValueAt(1,9)== "":
				newData2 = system.dataset.setValue(table, 1,9, "Red")
			if table.getValueAt(2,9) =="":
				newData3 = system.dataset.setValue(table, 2,9, "Red")
			if table.getValueAt(3,9) =="":
				newData4 = system.dataset.setValue(table, 3,9, "Red")
			if table.getValueAt(4,9) =="":
				newData4 = system.dataset.setValue(table, 4,9, "Red")
			if table.getValueAt(5,9) =="":
				newData4 = system.dataset.setValue(table, 5,9, "Red")
			if table.getValueAt(6,9) =="":
				newData4 = system.dataset.setValue(table, 6,9, "Red")
			if table.getValueAt(7,9) =="":
				newData4 = system.dataset.setValue(table, 7,9, "Red")
			if table.getValueAt(8,9) =="":
				newData4 = system.dataset.setValue(table, 8,9, "Red")
		elif system.date.getHour24(timeTag) == k:
#			if table.getValueAt(0,10) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,10, "Red")
			if table.getValueAt(0,10) =="":
			if table.getValueAt(1,10)== "":
				newData2 = system.dataset.setValue(table, 1,10, "Red")
			if table.getValueAt(2,10) =="":
				newData3 = system.dataset.setValue(table, 2,10, "Red")
			if table.getValueAt(3,10) =="":
				newData4 = system.dataset.setValue(table, 3,10, "Red")
			if table.getValueAt(4,10) =="":
				newData4 = system.dataset.setValue(table, 4,10, "Red")
			if table.getValueAt(5,10) =="":
				newData4 = system.dataset.setValue(table, 5,10, "Red")
			if table.getValueAt(6,10) =="":
				newData4 = system.dataset.setValue(table, 6,10, "Red")
			if table.getValueAt(7,10) =="":
				newData4 = system.dataset.setValue(table, 7,10, "Red")
			if table.getValueAt(8,10) =="":
				newData4 = system.dataset.setValue(table, 8,10, "Red")
			if table2.getValueAt(0,5) =="":
				twoData1 = system.dataset.setValue(table2, 0,5, "Red")
			if table2.getValueAt(1,5) =="":
				twoData1 = system.dataset.setValue(table2, 1,5, "Red")
		elif system.date.getHour24(timeTag) == l:
#			if table.getValueAt(0,11) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,11, "Red")
			if table.getValueAt(0,11) =="":
			if table.getValueAt(1,11)== "":
				newData2 = system.dataset.setValue(table, 1,11, "Red")
			if table.getValueAt(2,11) =="":
				newData3 = system.dataset.setValue(table, 2,11, "Red")
			if table.getValueAt(3,11) =="":
				newData4 = system.dataset.setValue(table, 3,11, "Red")
			if table.getValueAt(4,11) =="":
				newData4 = system.dataset.setValue(table, 4,11, "Red")
			if table.getValueAt(5,11) =="":
				newData4 = system.dataset.setValue(table, 5,11, "Red")
			if table.getValueAt(6,11) =="":
				newData4 = system.dataset.setValue(table, 6,11, "Red")
			if table.getValueAt(7,11) =="":
				newData4 = system.dataset.setValue(table, 7,11, "Red")
			if table.getValueAt(8,11) =="":
				newData4 = system.dataset.setValue(table, 8,11, "Red")
		elif system.date.getHour24(timeTag) == m:
#			if table.getValueAt(0,12) ==""and part =="16.9oz, 20.8g, Propel ":
#				newData1 = system.dataset.setValue(table, 0,12, "Red")
			if table.getValueAt(0,12) =="":
			if table.getValueAt(1,12)== "":
				newData2 = system.dataset.setValue(table, 1,12, "Red")
			if table.getValueAt(2,12) =="":
				newData3 = system.dataset.setValue(table, 2,12, "Red")
			if table.getValueAt(3,12) =="":
				newData4 = system.dataset.setValue(table, 3,12, "Red")
			if table.getValueAt(4,12) =="":
				newData4 = system.dataset.setValue(table, 4,12, "Red")
			if table.getValueAt(5,12) =="":
				newData4 = system.dataset.setValue(table, 5,12, "Red")
			if table.getValueAt(6,12) =="":
				newData4 = system.dataset.setValue(table, 6,12, "Red")
			if table.getValueAt(7,12) =="":
				newData4 = system.dataset.setValue(table, 7,12, "Red")
			if table.getValueAt(8,12) =="":
				newData4 = system.dataset.setValue(table, 8,12, "Red")
		elif system.date.getHour24(timeTag) ==n:
			table = system.tag.read("[.]EveryHourShift2").value
#			if table.getValueAt(0,1) ==""and part =="16.9oz, 20.8g, Propel ":
#				system.tag.write("[.]EveryHourShift2",newData1)
			if table.getValueAt(0,1)== "":
				system.tag.write("[.]EveryHourShift2",newData2)
				system.tag.write("[.]EveryHourShift2",newData3)
				system.tag.write("[.]EveryHourShift2",newData4)
		elif system.date.getHour24(timeTag) == o:
			table2 = system.tag.read("[.]Every2HourShift2").value
				system.tag.write("[.]Every2HourShift2",twoData1)
		elif system.date.getHour24(timeTag) == p:
			if table.getValueAt(0,3)== "":
		elif system.date.getHour24(timeTag) == q:
			if table.getValueAt(0,4)== "":
		elif system.date.getHour24(timeTag) == r:
#			if table.getValueAt(0,5) ==""and part =="16.9oz, 20.8g, Propel ":
			if table.getValueAt(0,5)== "":
Line 643 to 1243
		elif system.date.getHour24(timeTag) == s:
			if table.getValueAt(0,6)== "":
				newData4 = system.dataset.setValue(table,4,6, "Red")
				newData4 = system.dataset.setValue(table,5,6, "Red")
		elif system.date.getHour24(timeTag) == t:
			if table.getValueAt(0,7)== "":
		elif system.date.getHour24(timeTag) == u:
			if table.getValueAt(0,8)== "":
		elif system.date.getHour24(timeTag) == v:
			if table.getValueAt(0,9)== "":
		elif system.date.getHour24(timeTag) == w:
			if table.getValueAt(0,10)== "":
		elif system.date.getHour24(timeTag) == x:
			if table.getValueAt(0,11)== "":
		elif system.date.getHour24(timeTag) == a:
			if table.getValueAt(0,12)== "":
	else:
				newData1 = system.dataset.setValue(table, 0,1, "Blue")
				newData2 = system.dataset.setValue(table, 1,1, "Blue")
				newData3 = system.dataset.setValue(table, 2,1, "Blue")
				newData4 = system.dataset.setValue(table, 3,1, "Blue")
				newData4 = system.dataset.setValue(table, 4,1, "Blue")
				newData4 = system.dataset.setValue(table, 5,1, "Blue")
				newData4 = system.dataset.setValue(table, 6,1, "Blue")
				newData4 = system.dataset.setValue(table, 7,1, "Blue")
				newData4 = system.dataset.setValue(table, 8,1, "Blue")
				newData2 = system.dataset.setValue(table, 1,2, "Blue")
				newData3 = system.dataset.setValue(table, 2,2, "Blue")
				newData4 = system.dataset.setValue(table, 3,2, "Blue")
				newData4 = system.dataset.setValue(table, 4,2, "Blue")
				newData4 = system.dataset.setValue(table, 5,2, "Blue")
				newData4 = system.dataset.setValue(table, 6,2, "Blue")
				newData4 = system.dataset.setValue(table, 7,2, "Blue")
				newData4 = system.dataset.setValue(table, 8,2, "Blue")
				twoData1 = system.dataset.setValue(table2, 0,1, "Blue")
				twoData1 = system.dataset.setValue(table2, 1,1, "Blue")
				newData1 = system.dataset.setValue(table, 0,3, "Blue")
				newData2 = system.dataset.setValue(table, 1,3, "Blue")
				newData3 = system.dataset.setValue(table, 2,3, "Blue")
				newData4 = system.dataset.setValue(table, 3,3, "Blue")
				newData4 = system.dataset.setValue(table, 4,3, "Blue")
				newData4 = system.dataset.setValue(table, 5,3, "Blue")
				newData4 = system.dataset.setValue(table, 6,3, "Blue")
				newData4 = system.dataset.setValue(table, 7,3, "Blue")
				newData4 = system.dataset.setValue(table, 8,3, "Blue")
				newData1 = system.dataset.setValue(table, 0,4, "Blue")
				newData2 = system.dataset.setValue(table, 1,4, "Blue")
				newData3 = system.dataset.setValue(table, 2,4, "Blue")
				newData4 = system.dataset.setValue(table, 3,4, "Blue")
				newData4 = system.dataset.setValue(table, 4,4, "Blue")
				newData4 = system.dataset.setValue(table, 5,4, "Blue")
				newData4 = system.dataset.setValue(table, 6,4, "Blue")
				newData4 = system.dataset.setValue(table, 7,4, "Blue")
				newData4 = system.dataset.setValue(table, 8,4, "Blue")
				twoData1 = system.dataset.setValue(table2, 0,2, "Blue")
				twoData1 = system.dataset.setValue(table2, 1,2, "Blue")
				newData1 = system.dataset.setValue(table, 0,5, "Blue")
				newData2 = system.dataset.setValue(table, 1,5, "Blue")
				newData3 = system.dataset.setValue(table, 2,5, "Blue")
				newData4 = system.dataset.setValue(table, 3,5, "Blue")
				newData4 = system.dataset.setValue(table, 4,5, "Blue")
				newData4 = system.dataset.setValue(table, 5,5, "Blue")
				newData4 = system.dataset.setValue(table, 6,5, "Blue")
				newData4 = system.dataset.setValue(table, 7,5, "Blue")
				newData4 = system.dataset.setValue(table, 8,5, "Blue")
				newData1 = system.dataset.setValue(table, 0,6, "Blue")
				newData2 = system.dataset.setValue(table, 1,6, "Blue")
				newData3 = system.dataset.setValue(table, 2,6, "Blue")
				newData4 = system.dataset.setValue(table, 3,6, "Blue")
				newData4 = system.dataset.setValue(table, 4,6, "Blue")
				newData4 = system.dataset.setValue(table, 5,6, "Blue")
				newData4 = system.dataset.setValue(table, 6,6, "Blue")
				newData4 = system.dataset.setValue(table, 7,6, "Blue")
				newData4 = system.dataset.setValue(table, 8,6, "Blue")
				twoData1 = system.dataset.setValue(table2, 0,3, "Blue")
				twoData1 = system.dataset.setValue(table2, 1,3, "Blue")
				newData1 = system.dataset.setValue(table, 0,7, "Blue")
				newData2 = system.dataset.setValue(table, 1,7, "Blue")
				newData3 = system.dataset.setValue(table, 2,7, "Blue")
				newData4 = system.dataset.setValue(table, 3,7, "Blue")
				newData4 = system.dataset.setValue(table, 4,7, "Blue")
				newData4 = system.dataset.setValue(table, 5,7, "Blue")
				newData4 = system.dataset.setValue(table, 6,7, "Blue")
				newData4 = system.dataset.setValue(table, 7,7, "Blue")
				newData4 = system.dataset.setValue(table, 8,7, "Blue")
				newData1 = system.dataset.setValue(table, 0,8, "Blue")
				newData2 = system.dataset.setValue(table, 1,8, "Blue")
				newData3 = system.dataset.setValue(table, 2,8, "Blue")
				newData4 = system.dataset.setValue(table, 3,8, "Blue")
				newData4 = system.dataset.setValue(table, 4,8, "Blue")
				newData4 = system.dataset.setValue(table, 5,8, "Blue")
				newData4 = system.dataset.setValue(table, 6,8, "Blue")
				newData4 = system.dataset.setValue(table, 7,8, "Blue")
				newData4 = system.dataset.setValue(table, 8,8, "Blue")
				twoData1 = system.dataset.setValue(table2, 0,4, "Blue")
				twoData1 = system.dataset.setValue(table2, 1,4, "Blue")
				newData1 = system.dataset.setValue(table, 0,9, "Blue")
				newData2 = system.dataset.setValue(table, 1,9, "Blue")
				newData3 = system.dataset.setValue(table, 2,9, "Blue")
				newData4 = system.dataset.setValue(table, 3,9, "Blue")
				newData4 = system.dataset.setValue(table, 4,9, "Blue")
				newData4 = system.dataset.setValue(table, 5,9, "Blue")
				newData4 = system.dataset.setValue(table, 6,9, "Blue")
				newData4 = system.dataset.setValue(table, 7,9, "Blue")
				newData4 = system.dataset.setValue(table, 8,9, "Blue")
				newData1 = system.dataset.setValue(table, 0,10, "Blue")
				newData2 = system.dataset.setValue(table, 1,10, "Blue")
				newData3 = system.dataset.setValue(table, 2,10, "Blue")
				newData4 = system.dataset.setValue(table, 3,10, "Blue")
				newData4 = system.dataset.setValue(table, 4,10, "Blue")
				newData4 = system.dataset.setValue(table, 5,10, "Blue")
				newData4 = system.dataset.setValue(table, 6,10, "Blue")
				newData4 = system.dataset.setValue(table, 7,10, "Blue")
				newData4 = system.dataset.setValue(table, 8,10, "Blue")
				twoData1 = system.dataset.setValue(table2, 0,5, "Blue")
				twoData1 = system.dataset.setValue(table2, 1,5, "Blue")
				newData1 = system.dataset.setValue(table, 0,11, "Blue")
				newData2 = system.dataset.setValue(table, 1,11, "Blue")
				newData3 = system.dataset.setValue(table, 2,11, "Blue")
				newData4 = system.dataset.setValue(table, 3,11, "Blue")
				newData4 = system.dataset.setValue(table, 4,11, "Blue")
				newData4 = system.dataset.setValue(table, 5,11, "Blue")
				newData4 = system.dataset.setValue(table, 6,11, "Blue")
				newData4 = system.dataset.setValue(table, 7,11, "Blue")
				newData4 = system.dataset.setValue(table, 8,11, "Blue")
Lines 1244-1663
				newData1 = system.dataset.setValue(table, 0,12, "Blue")
				newData2 = system.dataset.setValue(table, 1,12, "Blue")
				newData3 = system.dataset.setValue(table, 2,12, "Blue")
				newData4 = system.dataset.setValue(table, 3,12, "Blue")
				newData4 = system.dataset.setValue(table, 4,12, "Blue")
				newData4 = system.dataset.setValue(table, 5,12, "Blue")
				newData4 = system.dataset.setValue(table, 6,12, "Blue")
				newData4 = system.dataset.setValue(table, 7,12, "Blue")
				newData4 = system.dataset.setValue(table, 8,12, "Blue")
#			table2 = system.tag.read("[.]Every2HourShift1").value
#			if table2.getValueAt(0,6) =="":
#				twoData1 = system.dataset.setValue(table2, 0,6, "Blue")
#				system.tag.write("[.]Every2HourShift1",twoData1)
#			if table2.getValueAt(1,6) =="":
#				twoData1 = system.dataset.setValue(table2, 1,6, "Blue")
				newData4 = system.dataset.setValue(table,4,6, "Blue")
JordanCClark I am just going to duplicate a Time tag from the other lines and go back through and remake the edits. It is a very long code and if it is something as silly as an indentation error then I dont want anyone parsing through my own error ridden code.
Plus, I should be able to catch it/not make the error again (hopefully) the second time around. Thank you for all your help!
Interesting. I copied and pasted your code into a function, and I didn't get the squiggly line.
If you figure it out, please post the solution.
Well that's interesting.
Even more interesting: It seems like the error comes at this point below. See how I have commented out the line and there is no error line in the top right-hand corner of the script, right below 'Enabled' (screenshot 1). But as soon as I uncomment the highlighted code, the red error line appears in the top right-hand corner (screenshot 2). I'm not sure what to make of it.
Screenshot 1
Screenshot 2
Interesting. I have that code in my copy, but it occurs at rows 798, so I must me missing almost two hundred lines somehow. I don't have the answer, but I do have a recommendation that could possibly help. It looks like hundreds of lines could be eliminated from this code with for loops to loop through the rows and columns of the dataset.
Something like this:
for row in range(table.rowCount):
	for column in range(table.columnCount):
		if table.getValueAt(row, column) =="":
			newData = system.dataset.setValue(table, row, column, "Red")
			system.tag.write("[.]EveryHourShift1",newData)
The EveryHourShift could probably be iterated in some way as well.
Thank you for the suggestion. This is our older version of Ignition that I am now in charge of maintaining. Unfortunately I have inherited a lot of this project, so I am constantly running into issues like this.
I figured since the code was so repetitive there had to be a better way to iterate through each line, however I am still fairly very new when it comes to coming up with my own code.
I truly appreciate your suggestion, I will have to take a day and dive in and try to reiterate to save time when I have to add in a new machine, as it takes about 20 min right now to go through the 1600 lines of code just to manually add in. Thank you for your time.
And for anyone who is wondering about the solution it looked like I ran through the tag character or line limit. It started working once I split the code into two separate tags.
Damn I've never seen so many ifs before !
I'm up for helping you with a refactor, if you can explain the logic behind all this.
Like, what's table, what does it contain, how does it impact the tag writes, can several of those conditions be true (since it's only if and not elif, and there's only 2 tags that can be written to, only the last true condition for each of those 2 tags actually does something. Which means you could be overwriting the same tag over and over again hundreded of times, which is FAR from something you want to be doing)
(I'm so sad that I couldn't find a gif)
Not to mention this is all being done in a Tag Event Script. There is a very good chance that there are events being missed.
I highly recommend taking Pascal up on his offer. He's done many refactors on this site, and he does excellent work.
I took a closer look, and there are a few things that need to be cleared:
  • It actually won't be overwriting hundreds of tags, as at most one of the a, b, c... branches will ever be executed, which means 11 writes at most.
  • who the hell thought of this a = 6, b = a + 1... madness ? What is going on here ?
    I can see there are 24 of them and they correspond to hours, but... Why make it even less clear ?
    Why is s midnight ? Why does b (7) correspond to the first column (I suspect a day starts at 7 ?) ?
    Why is the every2hoursShift not ACTUALLY every 2 hours ?
  • When an innermost branch is entered, do you want to change the color for every cell that's empty, or just the last one ?
  • Can there actually be several empty cells in the same column ?
    Currently, it only does it for the last one, as the same base table is used in each condition, which means if the first cell is empty, it's value is changed, the tag is written, but then if another cell is also empty, this previous change is discarded. Is that intended behavior ?
  • Are the two main branches strictly identical, except for the color ?
I can reduce all this to something that would actually be maintainable without changing what it does, but with more information it may be possible to go further and make the logic a bit less confusing.
Okay so here's a first draft that should be functionally equivalent, except on one point: it writes the color value in every empty cell from the processed column. This seemed like the most logical thing to do.
If that's not the expected behavior, I'll do another version.
Note: I insist on should, because frankly I might have missed quirks somewhere in the 1600 lines of ifs :X
I don't like that there are 2 separate tag reads, but it was simpler this way.
I might do another pass on this a bit later and see what can be improved, but for now I think I'll go put my head in the oven.
Just so you know, the file I used while doing this was named if_hell.py.
PMStatus = system.tag.readBlocking(["[.]PMStatus"])[0].value
if PMStatus:
	tags_paths = ["[.]EveryHourShift1", "[.]Every2HourShift1"]
	color = "Red"
else:
	tags_paths = ["[.]EveryHourShift2", "[.]Every2HourShift2"]
	color = "Blue"
shift1h, shift2h = [
	system.dataset.toPyDataSet(qval.value)
	for qval in system.tag.readBlocking(tags_paths)
hour = system.date.getHour24(currentValue.value)
col_index_1h = (hour - 6) % 12
col_index_2h = col_index_1h / 2
def fill_empty_cells(ds, col_index, value):
	for row in ds:
		if row[col_index] == "":
			row[col_index] = value
fill_empty_cells(shift1h, col_index_1h, color)
if col_index_2h in [8, 10, 12, 14, 16, 20, 22, 0, 2, 4]:
	fill_empty_cells(shift2h, col_index_2h, color)
shift1h = system.toDataSet(shift1h)
shift2h = system.toDataSet(shift2h)
system.tag.writeBlocking(tags_paths, [shift1h, shift2h])
very fitting,
i hope not all code is like this, else you sure have your work cut out for you xd
if you wrote this though, i suggest you loop up who loops work in python
1600 lines of code reduced to less than 25 lines of code: Nicely done :+1:
