Why NamedQuery can't run in Script
Using ‘NameQuery’ to run in script program will report an error
The Script:
params = {'bay':'BAY4', 'lot':'593301'}
system.db.runNamedQuery("Get_Prev_Thick", params)
the 'Get_Prev_Thick' content is :
SELECT
 	attribute_value
FROM
	NULLID.WIP_TASK
WHERE
	lot_number != :lot
	AND bldg_subsection = :bay
	AND task_code = '0010'
ORDER BY production_date DESC
FETCH FIRST 1 ROW ONLY
The 'Get_Prev_Thick' content picture:
Run it in script:
But I can run it in NamedQuery Vision:
I took the contents of 'namedQuery' out and ran it with 'runPrepQuery' , it worked fine.
I don't know what happened? The Ignition Version is 7.9.20
the error code is :
Java Traceback:
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.Py.JavaError(Py.java:488)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
	at org.python.core.PyObject.__call__(PyObject.java:404)
	at org.python.core.PyObject.__call__(PyObject.java:408)
	at org.python.pycode._pyx87.f$0(<buffer>:19)
	at org.python.pycode._pyx87.call_function(<buffer>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.Py.runCode(Py.java:1275)
	at org.python.core.Py.exec(Py.java:1319)
	at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:215)
	at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:89)
	at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:70)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:476)
	at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:464)
	at javax.swing.SwingWorker$1.call(SwingWorker.java:295)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at javax.swing.SwingWorker.run(SwingWorker.java:334)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:750)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.ibm.db2.jcc.am.mo: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=SELECT
 	attribute_value
FROM
;BEGIN-OF-STATEMENT;<query_expr_body>, DRIVER=4.7.85
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:353)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:327)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:280)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:912)
	at com.inductiveautomation.ignition.designer.db.namedquery.NamedQueryDesignerRpc.execute(NamedQueryDesignerRpc.java:64)
	at com.inductiveautomation.ignition.designer.db.namedquery.NamedQueryDesignerRpc.execute(NamedQueryDesignerRpc.java:39)
	at com.inductiveautomation.ignition.client.script.ClientDBUtilities.runNamedQuery(ClientDBUtilities.java:90)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	... 20 more
Caused by: java.lang.Exception: com.ibm.db2.jcc.am.mo: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=SELECT
 	attribute_value
FROM
	at com.inductiveautomation.ignition.gateway.project.NamedQueryExecutor$NamedQueryInstance.execute(NamedQueryExecutor.java:315)
	at com.inductiveautomation.ignition.gateway.project.NamedQueryExecutor.execute(NamedQueryExecutor.java:121)
	at com.inductiveautomation.ignition.gateway.project.ProjectManagerImpl.executeNamedQuery(ProjectManagerImpl.java:2204)
	at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryGatewayRpc.execute(NamedQueryGatewayRpc.java:29)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.NamedQueryFunctions.executeNamedQuery(NamedQueryFunctions.java:69)
	at sun.reflect.NativeMethodAccessorImpl.invoke(null)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
	at java.lang.reflect.Method.invoke(null)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:211)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:432)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
	at org.eclipse.jetty.servlet.ServletHolder$NotAsyncServlet.service(ServletHolder.java:1391)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:760)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:547)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
	at org.eclipse.jetty.server.Server.handle(Server.java:500)
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
	at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
	at java.lang.Thread.run(null)
  File "<buffer>", line 3, in <module>
 	attribute_value
FROM
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.ibm.db2.jcc.am.mo: DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=SELECT
 	attribute_value
FROM
When it fails, where are you calling it from? It looks like your DB2 driver is choking on syntax. (Did you save your project after editing the named query?)
The 'NamedQuery' have runed fine for serval years in version 7.9.10
recently i update to 7.9.20, it doesn't work.
other NamedQuery are normally
Something changed in the DB2 driver. Investigate that. Open a support ticket if necessary for IA to look over your shoulder.
And you haven't answered this part.
