Why won't my scheduled email script attach the excel file?
I created a scheduled script to run a query and attach the table to a email but when I run it, I don't have the attachment. Am I supposed to create the file on the hard drive temporally then attach it?
type or paste code h
# Run named query to get data
	results = system.db.runNamedQuery("Alarms", {})
	spreadsheet = system.dataset.toExcel(True, [results])
	fileName = "Alarms.xlsx"
	fileData = system.dataset.toExcel(True, [results])
	body = "<HTML><BODY><H1>This is a big header</H1>"
	body += "TEST1 <font color='red'>red</font></BODY></HTML>"
	recipients = ["email@email.com"]
	smtpProfile = "Email"
	attachments = [(fileName, spreadsheet)]  # Pass the filename and data as a tuple in a list
	system.net.sendEmail(
    smtpProfile=smtpProfile,
    fromAddr="email@email.com",
    subject="Here is the email!",
    body=body,
    html=1,
    to=recipients,
    attachments=attachments
	)ere
The issue is to do with the attachments parameter in system.net.sendEmail. This function requires the parameters List[String] attachmentNames and List[Byte] attachmentData for attachments. See in the manual:
https://docs.inductiveautomation.com/display/DOC81/system.net.sendEmail
Thank you, I finally got it to work. For anyone else that has difficulties with smtp profile and excel attachment in the future, here is my code for reference:
#runs named queries
	result1 = system.db.runNamedQuery("Alarms",{})
	result2 = system.db.runNamedQuery("ID",{})
#takes results then places them on separate sheets in excel
	spreadsheet = system.dataset.toExcel(True, [result1,result2], [], ["Alarm1","ID"])
	filePath = "Alarm Combined.xlsx"
#Send email via smtp profile
	body = "<HTML><BODY>This report is automatically generated."
	#body += "And this text is <font color='red'>red</font></BODY></HTML>"
	recipients = ["example@gmail.com"]
	smtp_server = "your smtp profile"
	system.net.sendEmail(smtpProfile=smtp_server,
	fromAddr="noreply@gmail.com", subject="Alarms Excel File",
	body=body, html=1, to=recipients, attachmentNames=[filePath],
	attachmentData=[spreadsheet])
