Wicket protocol/jetty errors
On starting/re-starting my Ignition module in Ignition, I get following errors in the log file (although my module works fine despite the errors!). What are these errors and how to fix them?
[color=#0000FF]INFO | jvm 1 | 2016/10/18 15:39:53 | 2016-10-18 15:39:53.396:WARN:oejs.ServletHandler:qtp4518619-994: /main/web/config/conf.modules
INFO | jvm 1 | 2016/10/18 15:39:53 | org.apache.wicket.protocol.http.servlet.ResponseIOException: org.eclipse.jetty.io.EofException
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.apache.wicket.protocol.http.servlet.ServletWebResponse.flush(ServletWebResponse.java:268)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.apache.wicket.protocol.http.HeaderBufferingWebResponse.flush(HeaderBufferingWebResponse.java:92)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:198)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.Server.handle(Server.java:518)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
INFO | jvm 1 | 2016/10/18 15:39:53 | at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
INFO | jvm 1 | 2016/10/18 15:39:53 | at java.lang.Thread.run(Thread.java:745)
INFO | jvm 1 | 2016/10/18 15:39:53 | Caused by:
INFO | jvm 1 | 2016/10/18 15:39:53 | org.eclipse.jetty.io.EofException[/color]
This happens only when I restart my module. When my module is started for the first time (starting GCU first time, starts my module automatically), there are no errors in the log file, only when I restart it from Configuration page of Ignition, it restarts but gives these wicket/jetty errors! Incidentally, I am creating 3 threads in my module which wait for external communication. It is something to do with exception on stopping threads?
Prafull
No these cannot be as a result of closing threads as the threads close successfully and restart as printed in log file. But I get the WARN immediately after my module shuts down and restarts again and the three threads are created successfully. This was not happening in Ignition versions upto 7.7.8, its happening from from 7.8 onward. Although my module is working fine and communicating with the external application successfully, but its not a good feeling until the warning is removed.
Can someone help in understanding and resolving the issue that's causing the problem?
The complete trace in the log file is as given below:
[color=#0000FF]
INFO | jvm 1 | 2016/10/25 11:00:08 | 2016-10-25 11:00:08.684:WARN:oejs.ServletHandler:qtp744373-915: /main/web/config/conf.modules
INFO | jvm 1 | 2016/10/25 11:00:08 | org.apache.wicket.protocol.http.servlet.ResponseIOException: org.eclipse.jetty.io.EofException
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.apache.wicket.protocol.http.servlet.ServletWebResponse.flush(ServletWebResponse.java:268)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.apache.wicket.protocol.http.HeaderBufferingWebResponse.flush(HeaderBufferingWebResponse.java:92)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:198)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.Server.handle(Server.java:518)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
INFO | jvm 1 | 2016/10/25 11:00:08 | at java.lang.Thread.run(Thread.java:745)
INFO | jvm 1 | 2016/10/25 11:00:08 | Caused by:
INFO | jvm 1 | 2016/10/25 11:00:08 | org.eclipse.jetty.io.EofException
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:197)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:419)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:313)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:141)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpConnection$SendCallback.process(HttpConnection.java:724)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpConnection.send(HttpConnection.java:512)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpChannel.sendResponse(HttpChannel.java:668)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpChannel.write(HttpChannel.java:722)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:179)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpOutput.write(HttpOutput.java:163)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.HttpOutput.flush(HttpOutput.java:299)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.server.Response.flushBuffer(Response.java:1154)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.apache.wicket.protocol.http.servlet.ServletWebResponse.flush(ServletWebResponse.java:264)
INFO | jvm 1 | 2016/10/25 11:00:08 | java.io.IOException: An existing connection was forcibly closed by the remote host
INFO | jvm 1 | 2016/10/25 11:00:08 | at sun.nio.ch.SocketDispatcher.writev0(Native Method)
INFO | jvm 1 | 2016/10/25 11:00:08 | at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:55)
INFO | jvm 1 | 2016/10/25 11:00:08 | at sun.nio.ch.IOUtil.write(IOUtil.java:148)
INFO | jvm 1 | 2016/10/25 11:00:08 | at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:504)
INFO | jvm 1 | 2016/10/25 11:00:08 | at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:177)
INFO | jvm 1 | 2016/10/25 11:00:08 | 2016-10-25 11:00:08.686:WARN:oejs.HttpChannel:qtp744373-915: //localhost:8088/main/web/config/conf.modules?6-2.IBehaviorListener.0-demo&_=1477373404290
[/color]
