Wildcard search in Perspective Dropdown for navigating to stations by tag path
Hi all,
We’re working on a SCADA project in Ignition Perspective (version [8.3.10]) and need a search feature that lets operators find a station by its tag path and navigate straight to its view.
Current setup
We’re using the Dropdown component (ia.input.dropdown) as the search box, since its built-in search already handles filtering as the user types. The options are populated by a binding [query / script transform / tag browse] that returns each station’s tag path, for example:
[default]Station1/PS_01/Flow
[default]Station1/RSVR_02/Level
[default]Station2/ET_05/Level
Each option is { "label": <tag path or display name>, "value": <tag path> }. On selection, an onActionPerformed / property change script reads the value and calls system.perspective.navigate() to open the station view.
What we need
The built-in search only does a plain substring match. Operators often know part of the path but not the full structure, so we’d like wildcard support, for example:
  • Station1*Flow matches all flow tags under Station1
  • *RSVR*Level matches reservoir level tags in any station
  • PS_0? matches PS_01 to PS_09
Questions
  1. Is there any way to make the Dropdown’s built-in search support wildcards (*, ?), or extend its matching logic?
Any examples or suggestions would be appreciated.
Thanks,
Muhammed Ashik
The manual page shows an example of an autocomplete operation using the built-in search param.
It looks like you'll need to add a transform on your options property, either with a script (easiest but least performant) or an expression. Phil's Integration Toolkit module offers high-performance iteration abilities as expressions.
My toolkit includes a regular expression utility that might help you: rex()
As a side suggestion I would revisit this. Instead use a dataset tag that has the list of your station/tags and with columns for the label, tag_path, navigation path, etc. Then you can directly just bind the options to that without doing a tag browse. It'll be much more responsive for loading.
The query/tag browse could be moved to a scheduled task that runs occasionally as a sync just incase future stations get added or removed.
