Will the Mitsubishi Driver Work if the tags for the PLC are in old GX Developer
So I have worked with the Mitsubishi plc driver before in the past on previous company projects however those projects used GX works 2 and Above for the PLC Ladder logic to where all the tags are housed in the Mitsubishi PLC.
The Current Project that I have been assigned is with an older piece of equipment that uses the old Mitsubishi GX Works Developer to house the ladder logic and tags.
Will the Mitsubishi Driver still be able to see the tags and pull them in with such a old piece of software holding the ladder logic and tags or does the Mitsubishi plc need GXworks 2 or 3 to work with Igntion on the driver?
