Window Navigation Not Working
I have a window that won’t open in the client. At first the window navigation was working, then the folder the window was in got moved. I’ve since moved it backed, saved, closed and re-launched the project in the client.
I’m using a tree navigation to get to the window, for testing I placed two buttons on the screen to perform code 1 and one to perform code 2.
Code 1:
window = system.nav.openWindow('Quality/Ramco/Overview') system.nav.centerWindow(window)
Code 1 Error:
[code]Traceback (most recent call last):
File “event:actionPerformed”, line 6, in
ValueError: Window Quality/Ramco/Overview does not exist.
at org.python.core.Py.ValueError(Py.java:309)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities$5.run(NavUtilities.java:449)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:706)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:375)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:364)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:428)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at org.python.pycode._pyx6.f$0(<event:actionPerformed>:7)
at org.python.pycode._pyx6.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:624)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy20.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Ignition v7.7.4 (b2015033012)
Java: Oracle Corporation 1.8.0_51
[/code]
Code 2:
window = system.nav.openWindow('Quality/Ramco/Overview') system.nav.centerWindow(window) system.nav.closeParentWindow(event)
Code 2 Error:
at org.python.pycode._pyx11.f$0(<event:actionPerformed>:8)
at org.python.pycode._pyx11.call_function(<event:actionPerformed>)
[/code]
I’m not sure why it thinks the window doesn’t exist.
Window Path:
Is there an additional space at the end of the window name? That would make the name look the same as ‘Quality/Ramco/Overview’, but it would actually be 'Quality/Ramco/Overview ’
I have seen this issue before, you can try clearing the .ignition cache on the computer you are launching the client on. This is found in your user folder. Just delete the entire .ignition folder and all of its contents. This will force a fresh download of the project. If that doesn’t work, try renaming the root folder the window(s) are in and correct the paths to the windows in your navigation scripts. This should fix the issue.
