I have a window opened script on a docked (navigation) view that relies on same gateway tags.
I have a shortcut to the project launcher in the Windows startup folder and it does open automatically when the computer starts up, but this script doesn't seem to work quite properly on that initial startup. If I close the project and re-open it the script executes properly every time.
Is there something I can do within Ignition or the launcer to wait until the Gateway is "fully ready", or should I try to use a batch file in the startup folder or the task scheduler that opens the project?
