I was writing a scrip in one of my windows today and when I closed the window out and tried to open it back up I get this error before the window even opens up:
java.lang.ArrayIndexOutOfBoundsException: 0
at com.sun.beans.ObjectHandler.dequeueResult(Unknown Source)
at java.beans.XMLDecoder.readObject(Unknown Source)
at com.calmetrics.factoryhmi.application.model.WindowController.deserializeWindow(WindowController.java:564)
at com.calmetrics.factoryhmi.application.model.WindowController._loadWindow(WindowController.java:300)
at com.calmetrics.factoryhmi.application.model.WindowController.getWindow(WindowController.java:343)
at com.calmetrics.factoryhmi.application.FHMIApp.openWindow(FHMIApp.java:783)
at com.calmetrics.factoryhmi.application.FHMIApp.openWindow(FHMIApp.java:764)
at com.calmetrics.factoryhmi.designer.model.ObjectHolder.openWindow(ObjectHolder.java:2075)
at com.calmetrics.factoryhmi.designer.navtree.ProjectBrowserPanel.mousePressed(ProjectBrowserPanel.java:421)
at java.awt.AWTEventMulticaster.mousePressed(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
I cannot get access to the window at all. Is there a way I can just view the code for the window and delete the script I wrote? Or is this not even the problem. The script is being run when a button is pushed and that is the only thing I can think that went wrong. Thanks!
