Windows 10 Touchscreen Function
I know this isn’t an Ignition issue, but it is a problem for me with Ignition nonetheless.
I have read the forums regarding this issue, but cannot seem to find a suitable solution.
I am having to double tap buttons for them to work.
Navigation buttons seem to work fine.
When I press and hold, a square box expands on the screen ( a Windows thing).
I have changed the registry Touchmode_Hold to 0 but it has made no difference
Any advice would be graciously received.
If you're using Elo Touch drivers, have you tried the solution here?
I added details of a configuration that's working as expected for us to the end of that thread:
This worked perfectly.
Thank you!!!
