Hi again,
Has anyone experience with Windows 2008 R2 Server HA architecture and load-balancing with Ignition ?
Thanks.
Hi again,
Thanks.
What information in particular are you looking for? Off the top of my head, I would say that licensing would be something to keep in mind. Your Ignition license will fail if the hardware profile reported to java changes, which may happen in a load balanced environment.
Michael,
Yes you’re right, this was one of my concerns (licensing). Other concerns may be with will it be installable ? I don’t see why not (Java is know to work on cluster environnement), but would like to have IA or other users advices.
Ignition will work for you without a problem. Our CDKeys allow for virtual machines to run in a hardware cluster environment.
Thank you Robert, this is a really good answer for our project !
