Hi
I have a client who uses active directory with roaming desktop and profiles for users, when Launching Ignition the install fails with a Access Denied Error such as
Error launching application:
FileNotFoundException:
\deesfs01\Desktop$\johndoe.ignition\cashe\gw10.35.10.32_80_8043_main\clients.lck
(Access is denied)
The file name specified is on the fileserver hosting the roaming desktop/profiles.
The IT department have set permissions on the desktop to stop users saving work onto the desktop, if this is disabled the ignition client will install correctly and run, but will fail to run if the permissions on the desktop set back after install.
The Roaming Profiles directory has full permissions to read/write, it is only the roaming desktop that has no write permissions. The IT Dept are reluctant to return to allowing users to write to the desktop and therefore the Ignition client will not run.
Any advice on how to work around this if it is possible would be appreciated.
Regards
Malcolm Bird
Swift Automation
UK
