I am setting up badge authentication on a vision project. I have been able to successfully login using a local user with my badge reader, but I am having issues trying to sign in using Windows AD.
I have my identity provider set up for badge authentication, and the user source is set to my Windows AD user source (testProfile).
In Windows AD I have put my badge number under the attribute “employeeID”. From my understanding that is what should be entered in the Badge Attribute parameter in the user source advanced settings, and I based my Badge Search Filter off of the example it provides.
I’ve made sure to set the proper user source and IdP in my vision project properties. I am able to sign in using my Windows AD username/password, so I know that it is connected, but for some reason I get this error when I scan my badge.
I am new to Active Directory so I was hoping that someone would have some advice on things to troubleshoot, if I’ve set it up wrong on the gateway, or if I’m missing anything else. Thanks!
