Hi everyone! I need my client swap automatically between 5 Windows in few seconds,
how can i manage this? I tried with a client script but I failed. Thank you for your help!
For rotating displays like this, I follow this procedure:
set all of the windows to open on startup.
use a client tag as a pointer to which window should be on top (I use one called ScreenPointer)
a client timer script to set the pointer:
pointer = system.tag.read('[Client]ScreenPointer').value
pointer += 1
if pointer > 5: #if max number of screens is 5
pointer = 1
system.tag.write('[Client]ScreenPointer')
- on each window (this is not a root container property, you have to highlight the window name), set the layer property to either 1 if it needs to show or 99 if it doesn’t. For example, if it’s the third window:
if({[Client]ScreenPointer} = 3, 1, 99)
This method uses more client memory, because you’re opening all the windows at once, but the transitions are seamless.
thanks for your help…could you be more specific on steps to follow for each Windows? thank you
Perfect. Just what I needed. Thanks Jordan.
