Windows Headless Server Downloading Ignition
I am trying to download ignition installare in a windows headless server usigin powershell. but it seems impossible. Any Idea?
Invoke-WebRequest -UseBasicParsing -Uri "https://files.inductiveautomation.com/release/ia/8.1.33/20231019-1423/ignition-8.1.33-windows-64-installer.exe"
Invoke-WebRequest : Errore del server remoto: (403) Non consentito.
In riga:1 car:1
+ Invoke-WebRequest -UseBasicParsing -Uri "https://files.inductiveautom ...
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebExc
   eption
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
Headless Linux servers require a referer for the download. Something similar might be applicable?
See here:
Thanks, I saw this post before write my post and this doesn't work on windows
You will have to translate curl to corresponding settings on PowerShell's Invoke-WebRequest. That's on you for using a lame operating system.
I find the solution
Invoke-WebRequest -UseBasicParsing -Headers @{'Referer'= 'https://inductiveautomation.com/downloads/ignition'} -URI 'https://s3.amazonaws.com/files.inductiveautomation
.com/release/ia/8.1.33/20231019-1423/ignition-8.1.33-windows-64-installer.exe' -OutFile ignition8133.exe
Incase anyone needs the latest linux version, it will same some folks some time.
curl -L -O -H 'Referer: Current Ignition Release | Inductive Automation' https://s3.amazonaws.com/files.inductiveautomation.com/release/ia/8.1.48/20250429-1106/ignition-8.1.48-linux-64-installer.run
