Something is wrong in the designer when you do this:
- Open a window
- Right click the window on the project explorer and select “Notes…”
- Write some notes and press OK
- Save the project
- Close the window (select YES to commit)
It thows this error:
java.lang.RuntimeException: ERROR. Resource 5 updated without obtaining lock.
at com.inductiveautomation.ignition.designer.DesignerContextImpl.updateLock(DesignerContextImpl.java:367)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.saveContainer(WindowWorkspace.java:1510)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.onClose(WindowWorkspace.java:1118)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace.close(AbstractDesignableWorkspace.java:364)
at com.inductiveautomation.ignition.designer.designable.AbstractDesignableWorkspace$1.actionPerformed(AbstractDesignableWorkspace.java:89)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$CloseTabAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$1.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
Ignition v7.4.2 (b953)
Java: Sun Microsystems Inc. 1.6.0_31
Regards
