Windows7- Java7 & WindXp-Java6 Ignition Gateway incompatible
Dear Brothers,
please consider this situation,
  1. Ignition Gateway server installed on windows xp machine with java6
  2. Runtime launched on Windows 7 machine with Java7
We are encountering the following issue:
  1. When I launch the Designer on Windows 7 machine and try to edit the windows,
    the windows which I worked upon and saved is loosing its formatting
What version of Ignition do you have?
V7.3.3
Are you SURE you’ve running 7.3.3? From the 7.3.3 changelog:
[quote=“Changelog”]Vision - 5.3.3.328
Designer
    Fixed - Background colors and fonts could not be saved correctly when the Designer was running in Java 7.[/quote]
tested working thanks…
thing is because of JAVA 7?/
ISNT IT???
