I have a customer using Wizcon 9.4 and it needs to be upgraded. I’ve investigated going with the Control Maestro…and would prefer not to.
Are there any tools or utilities to navigate taking the existing Wizcon 9.4 to an Ignition application?
TIA.
TIA.
None that I’m aware of. If there’s some documented standard format for Wizcon’s data, it might be doable to convert to Perspective’s view.json format manually, but you’ll have a very hard time manually creating Vision windows.
Also, generally conversion is not a good idea; inevitably ‘paradigms’ are sufficiently different between platforms that it’s not a good fit. Hopefully Ignition’s got enough niceties (UDTs, templates, etc) that it’s not too difficult to recreate from scratch.
