Hello,
Anyone can help me? I use vision for create HMI, in there we have tag from query tag (SQL Database). finally we have a Dataset. At root container we add new custom properties called “Data”, this is equal to Dataset from Query tag. when we add new components we use binding expression
{RootContainer.Data[row,colum]}
Now, in perspective anyone can help me to binding one field of Dataset using expression or similar?
Thanks for your time
One quick way would be to use a Script Transform and do the following:
field = value.getValueAt(row, col)
value being the incoming value from the binding to the dataset.
Hope that helps.
here we look the Dataset Tag value. try the previous doesn´t work. We just need insert value.value into a numeric label or led display.
Can you help me?
Thanks for your time.
not sure what youve done wrong if it doesnt work. this is setup on a custom property however it makes no difference on a numeric field.
May I ask why you are storing values in a dataset tag rather then in another method?
Thank you, it´s working now…
we use dataset because we make a SQL Query from database, multi row, so the application is running at Ignition visión 7.9 and mobile… we are testing perspective for migration.
