Hello everyone, I have several stations, and for each station I have its corresponding Scada, how can I insert a google maps map and interact with it to search for those stations? Thank you very much.
Assuming you know the locations of the stations it shouldn’t be too hard to use Kymera’s third party map module.
https://inductiveautomation.com/moduleshowcase/module/kymera-systems-inc-kymera-map-panel-module
It doesn’t use google maps however, instead it uses OpenStreetMaps, but those are practically the same in most integrated use cases.
Didn't quite understand your requirements, but we have a google-maps based geo-location tracking module for Ignition, if it makes any sense to your requirements! https://youtu.be/WXITQdOxPZw
