Wrapper.log is too large
I have a problem with this file, its too large. Under the ingition.conf is set as default 1024MB so I have no idea how to solve it. Please I need your help.
there are some wrapper settings in the Ignition/data/igntion.conf file
The default configuration is to rotate the wrapper log when it grows past a configured size (defaults to keeping 5 rolled files of 10MB maximum size), e.g.:
# Maximum size that the log file will be allowed to grow to before
#  the log is rolled. Size is specified in bytes.  The default value
#  of 0, disables log rolling.  May abbreviate with the 'k' (kb) or
#  'm' (mb) suffix.  For example: 10m = 10 megabytes.
wrapper.logfile.maxsize=10m
# Maximum number of rolled log files which will be allowed before old
#  files are deleted.  The default value of 0 implies no limit.
wrapper.logfile.maxfiles=5
Typical causes of logfile rotation failure are something holding onto a lock on that file, something like an antivirus program, for example. At this point, you can try simply deleting it (recommend Shift-Delete to immediately delete versus trying to send to Recycle Bin). It will re-create the file automatically.
#Wrapper Java Properties
#Java Application
#Locate the java binary on the system PATH:
#Specify a specific java binary:
set.JAVA_HOME=lib/runtime/jre-win
wrapper.java.command=%JAVA_HOME%/bin/java
#Tell the Wrapper to log the full generated Java command line.
#wrapper.java.command.loglevel=INFO
#Java Main class. This class must implement the WrapperListener interface
#or guarantee that the WrapperManager class is initialized. Helper
#classes are provided to do this for you. See the Integration section
#of the documentation for details.
wrapper.java.mainclass=org.tanukisoftware.wrapper.WrapperSimpleApp
#Java Classpath (include wrapper.jar) Add class path elements as
#needed starting from 1
wrapper.java.classpath.1=lib/wrapper.jar
wrapper.java.classpath.2=lib/core/common/*
wrapper.java.classpath.3=lib/core/gateway/*
#Java Library Path (location of Wrapper.DLL or libwrapper.so)
wrapper.java.library.path.1=lib
#Java Bits. On applicable platforms, tells the JVM to run in 32 or 64-bit mode.
#wrapper.java.additional.auto_bits=TRUE
wrapper.java.additional.auto_bits.macosx=FALSE
#Java Additional Parameters
wrapper.java.additional.1=-Ddata.dir=data
#wrapper.java.additional.2=-Xdebug
#wrapper.java.additional.3=-Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=*:8000
wrapper.java.additional.2=-Dedition=
#Initial Java Heap Size (in MB)
wrapper.java.initmemory=3024
#Maximum Java Heap Size (in MB)
wrapper.java.maxmemory=6048
#Application parameters. Add parameters as needed starting from 1
wrapper.app.parameter.1=com.inductiveautomation.catapult.Catapult
wrapper.shutdown.timeout=120
wrapper.jvm_exit.timeout=120
#Set this value to TRUE to allow ignition.conf to be reloaded when the JVM is restarted
wrapper.restart.reload_configuration=TRUE
#Wrapper Logging Properties
#Enables Debug output from the Wrapper.
#wrapper.debug=TRUE
#Format of output for the console. (See docs for formats)
wrapper.console.format=PM
#Log Level for console output. (See docs for log levels)
wrapper.console.loglevel=INFO
#Log file to use for wrapper output logging.
wrapper.logfile=logs/wrapper.log
#Format of output for the log file. (See docs for formats)
wrapper.logfile.format=LPTM
#Log Level for log file output. (See docs for log levels)
wrapper.logfile.loglevel=INFO
#Maximum size that the log file will be allowed to grow to before
#the log is rolled. Size is specified in bytes. The default value
#of 0, disables log rolling. May abbreviate with the 'k' (kb) or
#'m' (mb) suffix. For example: 10m = 10 megabytes.
#Maximum number of rolled log files which will be allowed before old
#files are deleted. The default value of 0 implies no limit.
#Log Level for sys/event log output. (See docs for log levels)
wrapper.syslog.loglevel=NONE
#Wrapper General Properties
#Allow for the use of non-contiguous numbered properties
wrapper.ignore_sequence_gaps=TRUE
#Title to use when running as a console
wrapper.console.title=Ignition Gateway
#Wrapper JVM Checks
#Detect DeadLocked Threads in the JVM. (Requires Standard Edition)
#wrapper.check.deadlock=TRUE
#wrapper.check.deadlock.interval=60
#wrapper.check.deadlock.action=RESTART
#wrapper.check.deadlock.output=FULL
#Out Of Memory detection.
#wrapper.filter.trigger.1000=java.lang.OutOfMemoryError
#wrapper.filter.action.1000=RESTART
#wrapper.filter.message.1000=The JVM has run out of memory.
wrapper.on_exit.default=SHUTDOWN
wrapper.on_exit.2=RESTART
#Wrapper Email Notifications. (Requires Professional Edition)
#Common Event Email settings.
#wrapper.event.default.email.debug=TRUE
#wrapper.event.default.email.smtp.host=<SMTP_Host>
#wrapper.event.default.email.smtp.port=25
#wrapper.event.default.email.subject=[%WRAPPER_HOSTNAME%:%WRAPPER_NAME%:%WRAPPER_EVENT_NAME%] Event Notification
#wrapper.event.default.email.sender=
#wrapper.event.default.email.recipient=
#Configure the log attached to event emails.
#wrapper.event.default.email.attach_log=TRUE
#wrapper.event.default.email.maillog.lines=50
#wrapper.event.default.email.maillog.format=LPTM
#wrapper.event.default.email.maillog.loglevel=INFO
#Enable specific event emails.
#wrapper.event.wrapper_start.email=TRUE
#wrapper.event.jvm_prelaunch.email=TRUE
#wrapper.event.jvm_start.email=TRUE
#wrapper.event.jvm_started.email=TRUE
#wrapper.event.jvm_deadlock.email=TRUE
#wrapper.event.jvm_stop.email=TRUE
#wrapper.event.jvm_stopped.email=TRUE
#wrapper.event.jvm_restart.email=TRUE
#wrapper.event.jvm_failed_invocation.email=TRUE
#wrapper.event.jvm_max_failed_invocations.email=TRUE
#wrapper.event.jvm_kill.email=TRUE
#wrapper.event.jvm_killed.email=TRUE
#wrapper.event.jvm_unexpected_exit.email=TRUE
#wrapper.event.wrapper_stop.email=TRUE
#Specify custom mail content
wrapper.event.jvm_restart.email.body=The JVM was restarted.\n\nPlease check on its status.\n
#Wrapper Windows NT/2000/XP Service Properties
#WARNING - Do not modify any of these properties when an application
#using this configuration file has been installed as a service.
#Please uninstall the service before modifying this section. The
#service can then be reinstalled.
#Name of the service
wrapper.name=Ignition
#Display name of the service
wrapper.displayname=Ignition Gateway
#Description of the service
wrapper.description=Ignition Gateway
#Service dependencies. Add dependencies as needed starting from 1
wrapper.ntservice.dependency.1=
#Mode in which the service is installed. AUTO_START, DELAY_START or DEMAND_START
wrapper.ntservice.starttype=AUTO_START
#Allow the service to interact with the desktop.
wrapper.ntservice.interactive=false
#VERSION - DO NOT MODIFY: 13
settings seem normal
Has the gateway service been restarted since those changes were made? They don't take immediate effect.
Actually I didn't make any changes, I misspelled on the first post, sorry for that.
There was a problem with user file permissions over Log directory, I had to ask IT team to give "Modify" permissions, erase that wrapper.log file and restart the gateway. :slight_smile:
