Write a tag to a txt file
Hello, I wonder if is possible to write a line break every time I write to a txt file
with this code I get the following
data = event.source.parent.getComponent('turno1').text filename = system.file.saveFile("MyDownloadedFile.txt") if filename != None: system.file.writeFile(filename, data,1)
[attachment=0]1.png[/attachment]
But I want something like this
[attachment=1]2.png[/attachment]
Sure, just append a newline character to data before you write it…
data = event.source.parent.getComponent('turno1').text + '\n'
Its not working with “notepad” but works with “wordpad”, It is possible to do this with notepad?
notepad:
[attachment=0]notas.png[/attachment]
wordpad:
[attachment=1]wordpad.png[/attachment]
Maybe you need to write a carriage return before the linefeed for notepad to pick it up… use ‘\r\n’ instead.
Thanks Keevin, That worked!
