Write Boolean Tag Error
I’d like to write bool tag by gateway event but sometimes it gives error as below. I have no idea why the error occurred randomly? It sometimes works but sometimes error occurs. Ignition Version: 8.1.13
Gateway Event Script , Three methods were used. The issue can’t be resolved.
system.tag.write(basePath + "/Test", 0)
system.tag.writeAsync([basePath + '/Test'], [0])
system.tag.writeBlocking(basePath + "/Test", 0)
Error Message ,when I use the function => system.tag.writeBlocking(basePath + “/Test”, 0)
java.util.concurrent.TimeoutException: null
at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.ignition.gateway.script.GatewayTagUtilities.writeBlockingImpl(GatewayTagUtilities.java:261)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.writeBlocking(AbstractTagUtilities.java:483)
at jdk.internal.reflect.GeneratedMethodAccessor529.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:541)
at org.python.core.PyObject.__call__(PyObject.java:477)
at org.python.core.PyObject.__call__(PyObject.java:481)
at org.python.pycode._pyx25927.f$0(:20)
at org.python.pycode._pyx25927.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1687)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:788)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:693)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:740)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runCode(ProjectScriptLifecycle.java:674)
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:242)
at com.inductiveautomation.ignition.common.script.TagChangeScriptExecutor$TagChangeExecutionCallback.execute(TagChangeScriptExecutor.java:194)
at com.inductiveautomation.ignition.common.util.SerialExecutionQueue$PollAndExecute.run(SerialExecutionQueue.java:102)
Tag Security
tagimg
system.tag.write is deprecated in v8+
In your aSync example you use single quotes.
I would suggest you use writeBlocking and follow the example from the user manual for the correct syntax:
# Create a list with the tag paths to be updated.
paths = ["[default]Folder/Tag_A","[default]Folder/Tag_B"]
# Create a list with the update values, one value for each path.
values = [1,2]
# Execute the write operation.
system.tag.writeBlocking(paths, values)
In your example of writeBlocking you have not included the square brackets around the tag path or values.
Timeouts on write can be caused by a device that is bogged down with too many subscription items. Look at the diagnostics for the device to see its current timing and overload statistics.
