Write text to a port 11002
Good morning,
I want to write a string to a port (11002) on the same PC my Ignition gateway is installed on. Does Ignition offer any built in functions to accomplish this?
Thanks for any info.
All of java’s built-in networking is available. java.net.Socket.
Thanks, I’ll look into Java solutions.
I came up with this code
import socket
import sys
TCP_IP = '127.0.0.1'
TCP_PORT = 11002
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect((TCP_IP, TCP_PORT))
s.send('some string of information')
s.close()
Spits out the length of the string in the console… I think it is working but the API on the device side is now my current problem.
Python’s socket package is notoriously buggy and slow in jython. I recommended the java classes very deliberately.
I feel like we have this conversation once a month pturmel. :grinning:
I need to sit down and just learn the syntax of Java.
Not syntax. You still use jython syntax for java classes inside jython. The methods are different.
