Write to Tags from Perspective Table
Good day,
I am reading a lot of posts about how to write to a tag from a perspective table but have not found a solution for what I am trying to do.
I would like to use a perspective table as an input for multiple indirect tags bound to each data prop element. I am not binding to the entire data prop, but instead items in each array:
I have tried using the following:
def runAction(self, event):
	valueToSet = event.value
	self.props.data[event.row]['value'][event.column] = valueToSet
and get the following error:
Error running action 'component.onEditCellCommit' on 9 Press KY/AgingOvenLoad@D/root/Table: Traceback (most recent call last): File "<function:runAction>", line 3, in runAction KeyError: value
Is this possible to do with a perspective table or am I going down a dark hole. Once this is setup, there will be a set amount of data points and the entire dataset will not change in size. Thanks!
Make sure cells are set to be editable under your columns property, then under onEditCellCommit event, use
self.props.data[event.row][event.column] = event.value
Thank you worked like a charm.
