My Module creates a custom TagProvider. This TagProvider dynamically creates and updates tags as needed. When a new tag is created, I run the registerWriteHandler() method for that tag.
class myWriteHandler implements WriteHandler {
SimpleTagProvider myTagProvider;
myTagProvider.updateValue(tagPath, tagValue, DataQuality.GOOD_DATA);
myTagProvider.registerWriteHandler(tagPath, myWriteHandler);
As you can see, I use the updateValue() method to both update AND create (if the tag doesn’t exist) tags in myProvider.
The Question:
Is it a problem that I register a write handler on a tag every time the tag is updated? Should I only register the write handler upon tag creation? If so, how do I check if a write handler has already been registered for a given tagPath?
