I have multiple buttons that will reading the same tag but I want a power table to update and read the tag data when the buttons are clicked. I'm new to ignition and unsure how to start.
If you have time i would start by completing the credential courses, specifically the ones related to Vision.
What you'll need is an actionPerformed script on your button and use the system.tag.readBlocking() (Or system.tag.read() if your ignition version is prior to 8.0.) and then use te results to update the table's dataset with system.dataset.setValue()
But to start on your objective you can take a look at the Vision Component Scripting videos.
