Writing tags to Historian at selected times during the day
I would like to write tag values to Historian at selected times during the day. I am new to Ignition and have not been able to find anything on the topic.
Easiest thing I know of to only record values into history at a selected time would be to do it manually with a script on a client tag using the system.tag.storeTagHistory function.
I think you could be asking one of two things: 1) β€œI want to store tag values only during certain times of the day, for other times I do not want any information stored to the Historian.” 2) β€œI want tag information stored for all day, but I only want Ignition to store it to SQL during certain hours.”
For #1, then you probably want to check the SQL Bridge Module out:
https://docs.inductiveautomation.com/display/DOC79/SQL+Bridge+Module
Set up transactions to run to store your data only during the times you need.
For #2, then change your Store and Forward Settings:
https://docs.inductiveautomation.com/display/DOC79/Store+and+Forward
make sure you make the cache and buffer sizes big enough to hold data from the parts of the day that you aren’t connecting in.
