we are having issues getting a Tag to be written from data pulled in from a web service,(“we are the Consumer”) we are getting the Data from the web-service but having issues writing one value to a tag.
can anyone post some Python Code or script of how they accomplish this
for Item in Product:
for Name in Item:
if Item[Name] is not None:
system.tag.write(“Product/” + str(Name), Item[Name]) #print “Product/” + str(Name) #print Item[Name] #print Name
As @MMaynard says, probably just missing the tag provider.
Though I would probably write this in such a way that only one write function is called.
For 7.9:
#if you want a one liner and don't care about optimization that much
paths, values = zip(*[('[default]Product/' + str(name),item[name]) for item in product for name in item if item[name] is not None])
system.tag.writeAll(list(paths),list(values))
#if you would rather have something a litle simpliar
paths = []
values = []
for Name in Item:
paths.append('[default]Product/' + str(Name)
values.append(Item[name])
system.tag.writeAll(paths,values)
Or for 8.* use the system.tag.writeBlocking()
system.tag.writeBlocking(paths,values)
Writing all of the tags with one call will fairly significantly speed up this bit of code, unless you only have 1 or 2 values that are being written as a result of this.
Also if you are using 8.* switching to writeBlocking will future proof your code as system.tag.write has been depricated.
I tested this I think it was with 400 writes. Writing all at once took something like 1.4% of the time it took to write 5 at a time (I was proving to someone else how much faster their code would be if they switched, so I didn't test writing tags singularly)
I knew this was the case, but I hadn't ever really quantified it, and your post made me curious, so I did this.
NOTE: This was in 7.9 script console
from java.lang import System
tagPaths = []
ret = 0
currentTime = system.date.now()
for i in range(400):
tagPaths.append('[Client]CurrentTime')
start = System.nanoTime()
ret = system.tag.write(tagPaths[i],currentTime)
end = System.nanoTime()
print '400 singular writes took %.3f ms' % ((end-start) / 1000000.0)
values = []
paths = []
values.append(currentTime)
paths.append('[Client]CurrentTime')
if i % 5 == 0:
ret = system.tag.writeAll(paths,values)
values = []
paths = []
print '400 writes in blocks of 5 took %.3f ms' % ((end-start) / 1000000.0)
values=[]
paths = []
print '400 writes in 1 block took %.3f ms' % ((end-start) / 1000000.0)
and here are the results
400 singular writes took 6.925 ms
400 writes in blocks of 5 took 2.864 ms
400 writes in 1 block took 0.879 ms
So writing 400 tags at once took 12.7% of the time it took to write 400 tags singularly and 3.1% of the time it took to write 5 at a time.
