I'm experiencing an odd error and I'm not sure how to resolve this.
I have a client startup script that has the following code:
system.tag.write("[Client]Special/startDate",system.date.format(system.date.now(),'MM/dd/yyyy 6:00:00'))
system.tag.write("[Client]Special/endDate",system.date.format(system.date.now(),'MM/dd/yyyy HH:mm:00'))
And for some reason it doesn't execute?
But the following code does in the same client startup script:
system.tag.write(clientTag, system.tag.read(tag).value)
Which indicates the client startup script is excecuting.
Furthermore, when I put the two lines of code above in a client timer script, it executes just fine.
Any suggestions?
