So I am not sure if this is intended or a bug or otherwise just an effect of the client tags.
However, I just had a scenario where I read a dataset from a client tag with the function system.tag.readBlocking and return the value in a parameter called result.
I manipulate the value and save the value in the result variable again:
result = system.tag.readBlocking(['[client]myTag'])
result[0].value = result[0].value + 1
All of this is done in a script in scripting library and called from button.
I have a label component bound to the client tag to show the value.
In the running client I test this and when the button is clicked the script is called but the label does not update. Just as expected.
However, if the I then save the project again and update the client (clicking on the banner in the top without closing the client) then the label component is updated.
How can this happen? I have not written back to the client tag itself so I would assume that this value was just saved in the local variable result and that’s it.
Is it because the memory between the client tag and the variable is shared in the scope of the client. So when I write back to that memory and the client is updated, then the client tag updates to that new value? I can see how that can be the intended functionality?
@paul-griffith or @Kevin.Herron can you share some light on this? I might be wrong here and everything is as it is supposed to be, I just don’t get how the value will update on a client update when I have never written to the tag in the first place.
Sounds like a client tag bug. I bet a copy isn’t being returned and you’re mutating the underlying value. No updates seen until restart because no events fire to notify listeners.
Ignition defines the Dataset type to be immutable, but implementations are actually mutable. Reading a dataset from a client tag (or from any tag in gateway scope) delivers the dataset object that is actually stored in the tag. You are not supposed to alter it, as any changes within do not change the object’s identity–yielding no change events. This is also true of dataset properties throughout Ignition’s object models.
(Causing the APIs to return copies would have undesirable negative performance effects. Just follow the rule. That is, not a bug.)
Use the scripting functions that alter and return a copy, or construct a new dataset after looping through the original.
