Writing to CODESYS OPC-UA Tags from Ignition Edge
I have implemented Ignition Edge on a Revolution Pi using CODESYS. I am able to see tag values in the Designer however when I try to write to the tags I get the following errors:
The tags are set to read/write in CODESYS and in the Designer as well. I believe I have disabled all security in the Gateway as well?
Did you set the toggle at the top of the designer to the read write mode?
That was it! Thanks for the incredibly speedy reply!
