I’m very new to Ignition, and am trying to setup data storage to my MariaDB database without requiring to open Ignition Designer and setting each tags History Enabled to true.
Is it possible to:
Set up so that every tag by default is has
History Enabled = trueand set a defaultStorage Provider(my database). -
Write directly from MQTT Engine to MQTT Recorder without the need of configuring a tag and using MQTT Transmission.
Kind Regards
Art
