X-Ignition-API-Token is being sent lowercase from browsers
openapi-fetch and all other fetch variants are forcing the header key to be lowercase, but the server doesn’t appear to honor it unless it’s the exact case of X-Ignition-API-Token. Anyone else seeing this or have a workaround?
Case insensitive on my end:
❯ curl -H 'x-ignition-api-token: myToken:8qxc9om0cfgey5iCI0_GVHkOr_TF1_nQr2DPMrwKzEg' http://localhost:8088/data/api/v1/gateway-info
{"name":"Ignition-DV-pgriffith-MBP","redundancyRole":"Independent","edition":"standard","hostname":"localhost","port":"8088","ignitionVersion":"(Dev Version)","deploymentMode":"","timeZone":"Pacific Standard Time","timeZoneId":"America/Los_Angeles","jvmVersion":"17.0.16","allowUnsignedModules":true,"license":{"mode":"Trial","validForVersion":0,"expirationDate":"Aug 18, 2025, 6:23:44 PM","licenseRestrictions":[]}}%
❯ curl -H 'X-Ignition-Api-Token: myToken:8qxc9om0cfgey5iCI0_GVHkOr_TF1_nQr2DPMrwKzEg' http://localhost:8088/data/api/v1/gateway-info
Thanks sir. Using beta3, and openapi-fetch it is fully ignored. I will keep researching. Related, have you been able to use any of the code generation tools with the openapi.json file? Autorest and openapi-generator-cli fail with many errors.
I think I am understanding the API to not support CORS. Is that true? Options requests even via CURL 404.
The API is no different than the rest of the gateway.
There's no support for setting arbitrary CORS headers (though it is something we want to add in some future release) but there are some configuration parameters you can set to manipulate some HTTP headers:
This makes sense then. I am trying to write a Tauri/React app and it uses browser based fetch which forces a proper CORS cycle. I will see what I can do to work around it.
When I run the "official" OpenAPI generator I do get some errors that prevent generating the schema (filed internally as bug IGN-13978; nothing there looks to be too hard to fix) but I can suppress those with a flag and get a valid client generated:
npx @openapitools/openapi-generator-cli generate -i openapi.json -g kotlin -o ./openapi --skip-validate-spec
YMMV - we're definitely not going to even attempt to validate against every possible client generator under the sun, but hopefully once we fix those easy errors most/all client generators should work.
Thanks again! The client gets generated with a few errors (~20 lines of code) that need to be manually fixed so I am working now. Thank you again!
