XML import tags name
I import a xml file to ignition and it says that a tag doesn’t have a valid name.
I dont see any illegal characters in the name.
I already running the latest version of ignition: 7.9.9
It is about the tag: Setting values ​​dosage control different
What is wrong in this name?
-this is not the only tag with this error where I dont see any illegal characters
xml command for this tag:
<Tag name='Setting values ​​dosage control different' path='Line 4/Feeder' type='OPC'>
<Property name='Value'/>
<Property name='DataType'>4</Property>
<Property name='OPCServer'>Ignition OPC-UA Server</Property>
<Property name='OPCItemPath'></Property>
</Tag>
That is not csv, that is XML…
sorry, put it good in the title but in the text not, it’s edited now :wink:
Solved, I had to set encoding to ANSI and convert it to UTF8
