Ignition Version 7.9.10 Trial Version
I am doing some very basic xml parsing and I keep running into an error:
oxml = """<PIM xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.summitekinstruments.com" xsi:schemaLocation="http://www.summitekinstruments.com PIMXMLSchema.xsd">
<Responses Legacy="false">
<Response Action="GetProducts" Units="">
<Status Error="true" Code="0">
<Message>This session is not connected to an instrument</Message>
</Status>
</Response>
</Responses>
</PIM>
from xml.etree import ElementTree as ET
root = ET.fromstring( oxml )
… and this yields the following error exactly every 10 runs …
Java Traceback:
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:204)
at org.python.core.PyObject.__call__(PyObject.java:387)
at org.python.core.PyObject.__call__(PyObject.java:391)
at xml.parsers.expat$py.__init__$3(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\parsers\expat.py:139)
at xml.parsers.expat$py.call_function(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\parsers\expat.py)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.PyBaseCode.call(PyBaseCode.java:301)
at org.python.core.PyBaseCode.call(PyBaseCode.java:194)
at org.python.core.PyFunction.__call__(PyFunction.java:387)
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:220)
at org.python.core.PyMethod.__call__(PyMethod.java:211)
at org.python.core.PyMethod.__call__(PyMethod.java:206)
at org.python.core.Deriveds.dispatch__init__(Deriveds.java:19)
at org.python.core.PyObjectDerived.dispatch__init__(PyObjectDerived.java:1057)
at org.python.core.PyType.type___call__(PyType.java:1565)
at org.python.core.PyType.__call__(PyType.java:1548)
at org.python.core.PyObject.__call__(PyObject.java:404)
at org.python.core.PyObject.__call__(PyObject.java:408)
at xml.parsers.expat$py.ParserCreate$1(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\parsers\expat.py:59)
at org.python.core.PyBaseCode.call(PyBaseCode.java:149)
at org.python.core.PyFunction.__call__(PyFunction.java:327)
at xml.etree.ElementTree$py.__init__$81(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\etree\ElementTree.py:1160)
at xml.etree.ElementTree$py.call_function(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\etree\ElementTree.py)
at org.python.core.PyFunction.__call__(PyFunction.java:381)
at org.python.core.PyInstance.__init__(PyInstance.java:120)
at org.python.core.PyClass.__call__(PyClass.java:194)
at org.python.core.PyObject.__call__(PyObject.java:371)
at org.python.core.PyObject.__call__(PyObject.java:375)
at xml.etree.ElementTree$py.XML$69(C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\etree\ElementTree.py:977)
at org.python.core.PyBaseCode.call(PyBaseCode.java:134)
at org.python.core.PyFunction.__call__(PyFunction.java:317)
at org.python.pycode._pyx31.f$0(<buffer>:15)
at org.python.pycode._pyx31.call_function(<buffer>)
at org.python.core.Py.runCode(Py.java:1275)
at org.python.core.Py.exec(Py.java:1319)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:215)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:89)
at org.python.util.InteractiveInterpreter.runsource(InteractiveInterpreter.java:70)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:476)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$InterpreterWorker.doInBackground(JythonConsole.java:464)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: org.xml.sax.SAXException: SAX2 driver class org.apache.xerces.parsers.SAXParser not found
java.lang.ClassNotFoundException: org.apache.xerces.parsers.SAXParser
at org.xml.sax.helpers.XMLReaderFactory.loadClass(Unknown Source)
at org.xml.sax.helpers.XMLReaderFactory.createXMLReader(Unknown Source)
at sun.reflect.GeneratedMethodAccessor58.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
... 56 more
Caused by: java.lang.ClassNotFoundException: org.apache.xerces.parsers.SAXParser
at java.net.URLClassLoader.findClass(Unknown Source)
at com.sun.jnlp.JNLPClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at com.sun.jnlp.JNLPClassLoader.loadClass(Unknown Source)
at org.xml.sax.helpers.NewInstance.newInstance(Unknown Source)
... 62 more
File "<buffer>", line 15, in <module>
File "C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\etree\ElementTree.py", line 975, in XML
parser = XMLTreeBuilder()
File "C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\etree\ElementTree.py", line 1133, in __init__
self._parser = parser = expat.ParserCreate(None, "}")
File "C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\parsers\expat.py", line 59, in ParserCreate
return XMLParser(encoding, namespace_separator)
File "C:\Users\conno\.ignition\cache\gwlocalhost_8088_8043_main\C0\pylib\xml\parsers\expat.py", line 91, in __init__
self._reader = XMLReaderFactory.createXMLReader(_xerces_parser_name)
org.xml.sax.SAXException: org.xml.sax.SAXException: SAX2 driver class org.apache.xerces.parsers.SAXParser not found
Attempts:
- validate XML formatting
- restart ignition
Thoughts?
