When trying to import SQL tags from an XML file, I get the following error. I have tried deleting the target folder prior to importing, have tried importing an unchanged XML export file just to see if my editor was changing something that should not be. I always get this result. The text below is from the detail tab of the error dialog box. The primary tab is blank.
org.xml.sax.SAXException
java.lang.NullPointerException
at com.inductiveautomation.ignition.common.xmlserialization.simple.SimpleXMLReader.endElement(SimpleXMLReader.java:159)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.endElement(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.common.xmlserialization.simple.SimpleXMLReader.parseFile(SimpleXMLReader.java:50)
at com.inductiveautomation.ignition.designer.sqltags.action.ImportTagAction$XMLTagImporter.run(ImportTagAction.java:234)
at com.inductiveautomation.ignition.client.util.gui.progress.ClientProgressManager$ClientRunningTask.run(ClientProgressManager.java:544)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:526)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.designer.sqltags.importexport.xml.TagXMLImporter$PermissionModelElement.addChild(TagXMLImporter.java:232)
at com.inductiveautomation.ignition.common.xmlserialization.simple.SimpleXMLReader.endElement(SimpleXMLReader.java:156)
… 25 more
Ignition v7.6.1-rc4 (b2257)
Java: Oracle Corporation 1.7.0_21
