(tried the cirrus-link forum.) (searched the cirrus-link github and ig github)
Getting pages and pages of these on our 4 edge nodes ipc machines that collect (and store) data in the field.
These edge nodes have local opc ua and history. Then they mqtt xmit to the main production ig gw.
com.cirruslink.efm.abbtotalflow.db2.register.protocol.xframe.XRegisterData (when highlight the warning first field)
| XRegisterData | 08Jan2023 22:15:53 | Failed to set data point String Template-0 of type STRING - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:53 | Failed to set data point Feedback of type Register - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:53 | Failed to set data point Float64 Template-9 of type DOUBLE - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:53 | Failed to set data point Uint64 Template-3 of type UINT64 - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:53 | Failed to set data point Int64 Template-9 of type INT64 - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:51 | Failed to set data point Float64 Template-9 of type DOUBLE - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:51 | Failed to set data point Uint64 Template-3 of type UINT64 - there is no data from the ABB Totalflow device |
| XRegisterData | 08Jan2023 22:15:51 | Failed to set data point Int64 Template-9 of type INT64 - there is no data from the ABB Totalflow device |
It is stopping some data points from being put into mqtt to be sent to the main production gateway pages.
Mqtt.fx shows packet flowing, but not all data points are listed in the sparkplugb DDATA packet. Some.
The result for the user - the main perspective pages on the main gateway that pull all the data items together - drop random web fields.
Tried restarting modules.
Restarting ABB TF module. Did not resolve issue for long. Also dropped the history charts on the edge node machine.
Restarting the OPC UA on the edge install - no change - or warning just returns in a few hours.
We did upgrade the mqtt xmit on jan 2 to .14. This was recommended by CLink for some backfill testing we were doing. But these errors have been there well before Jan 2.
Happy to dig more.
Anyone see this before?
Workaround?
Fix?
Spec on edge install
| Version: 8.1.19 (b2022072711) | |||
| License: licensed | |||
| Name | Version | License | Status |
| Alarm Notification | 6.1.19 (b2022072711) | Activated | RUNNING |
| Allen-Bradley Driver | 6.1.19 (b2022072711) | Activated | RUNNING |
| BACnet Driver | 2.1.19 (b2022072711) | Activated | RUNNING |
| DNP3 Driver | 4.1.19 (b2022072711) | Activated | RUNNING |
| Logix Driver | 5.1.19 (b2022072711) | Activated | RUNNING |
| Modbus Driver | 7.1.19 (b2022072711) | Activated | RUNNING |
| OPC-UA | 9.1.19 (b2022072711) | Activated | RUNNING |
| Omron Driver | 4.1.19 (b2022072711) | Activated | RUNNING |
| Perspective | 2.1.19 (b2022072711) | Activated | RUNNING |
| Serial Support Client | 6.1.19 (b2022072711) | Activated | LOADED |
| Serial Support Gateway | 6.1.19 (b2022072711) | Activated | RUNNING |
| Siemens Drivers | 6.1.19 (b2022072711) | Activated | RUNNING |
| Symbol Factory | 7.1.19 (b2022072711) | Activated | LOADED |
| Tag Historian | 4.1.19 (b2022072711) | Activated | RUNNING |
| UDP and TCP Drivers | 6.1.19 (b2022072711) | Activated | RUNNING |
| Vision | 11.1.19 (b2022072711) | Activated | RUNNING |
| Cirrus Link Solutions LLC | |||
| EFM ABB Totalflow Driver | 4.0.14-SNAPSHOT (b2022110402) | Activated | RUNNING |
| MQTT Transmission | 4.0.14 (b2022121422) | Activated | RUNNING |
yes snapshot on abb tf
