Is there way to manipulate the size of bullet labels on an XY Chart? The only way I've managed to do it so far is via the chart's style, but that affects the entire chart.
Seems like Ignition is using v4 of amChart. Play around with these settings. No guarantees all of these are exposed by IA but most of them seem to work for me.
https://www.amcharts.com/docs/v4/concepts/formatters/formatting-strings/#Visual_formatting
I was able to get a rough solution. I found that the y-axis of the screen never changed size, even when the window got larger or smaller. So I estimated the size of that (x), took the size of the user's screen (y), and got an available area (z = (y-x)). Then I broke that up based on the number of bars I was going to have and set the offsets accordingly.
