XY Chart , Date on X chart showing wrong values and overlapping
Hello,
I have data from database and displaying on the XY chart where X represents the date from the DB column. I am using it on a column container to display the charts. So the graph is being displayed like below when I launch the session.
After launching for a few seconds, the graph changes to something strange like below which scales the X graph and shows wrong data which is different from the data collected from the DB.
Thanks in advance community .
Tip: if the data is correct in Designer's XY Chart props.dataSources then the problem has nothing to do with database so you could remove that tag from the question.
I've used the XY Chart but I've never seen your issue. Please copy the XY Chart from the Project Browser and paste it here using the </> to format it properly (and you can use the gear icon → Hide Details to be cool). Since that will have the database binding on the dataSources you should copy the dataSources property and past that here separately (again formatting the code).
The data from the database .The data that is pulled from the data base is also not correct on the graph on the X axis. I fetched data from 1/05 to 1/11 , but it shows only data from 1/04 to 1/10 .
We can't really help you with the database query if you don't show it to us.
Please also mention what timezone the gateway is running in and what timezone the Perspective project is using (in Project Properties).
I ran into a similar issue. The chart would display correctly, then after a few seconds it would get all wonky like the charts you are showing. I was using a date field for my x-axis. The way that I ended up resolving the issue is sorting my data in ascending order by the date. I originally had my data sorted in descending order and as soon as I reversed that order it stopped having the issue. I ran across this post while looking for a solution. I just thought I would post here in-case anyone comes across this problem in the future. Maybe it’ll solve their problem.
