Hello,
This is my issue I am trying to correct in the x-axis label:
The x axis label comes from my data source: "label" column...
So, in my series setup, I call for the "label" column as my x-axis label. However is there anyway to wrap the "label" text in the highlighted item in the next screenshot?
What version are you on?
There is a rotate text option on newer versions.
(Only issue I have with rotating my text is not knowing how to control the chart/text height consistently.)
https://docs.inductiveautomation.com/display/DOC81/Perspective+-+XY+Chart
The doc shows a wrap below rotate, but has to be manually added. Says after 8.1.10 maybe?
Great!! Thank you very much for the information
