XY Chart Label Shadow/Outline and Legend
Is is possible to add a shadow/outline to the column labels, I would prefer them to be white but they disappear when the bar is low.
Also, I use one series and then use deriveFieldsFromData to change the color of each category, I'm curious if I can have a legend representation for each category/column? I feel like I should be able to.
Thanks.
Can you paste your chart JSON here? (Right-click on the chart in the Project Browser and select Copy.) Format it properly as code using the </> button.
Definitely, here it is.
  "custom": {
    "Chart_Information": [
        "color": "#507fcb",
        "name": "CMM",
        "value": 180
        "color": "#6da7e3",
        "name": "Cap Asm",
        "value": 86
        "color": "#91a1fd",
        "name": "Thickness \u0026 Leakage",
        "value": 36
        "color": "#b75dd0",
        "name": "Leakage \u0026 Torque",
        "value": 25
        "color": "#d45683",
        "name": "Level Sensor Asm",
        "value": 5
  "params": {},
  "propConfig": {
    "custom.Chart_Information": {
      "persistent": true
  "props": {
    "defaultSize": {
      "height": 400
  "root": {
    "children": [
        "meta": {
          "name": "topQualityIssueChart"
        "position": {
          "basis": "400px"
        "propConfig": {
          "props.dataSources.Chart_Data": {
            "binding": {
              "config": {
                "path": "view.custom.Chart_Information"
              "type": "property"
        "props": {
          "dataSources": {},
          "series": [
              "candlestick": {
                "appearance": {
                  "deriveFieldsFromData": {
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": "",
                    "min": ""
                  "stacked": false,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                "high": {
                  "x": "",
                  "y": ""
                "low": {
                  "x": "",
                  "y": ""
                "open": {
                  "x": "",
                  "y": ""
              "column": {
                "appearance": {
                    "fill": {
                      "color": "color",
                      "opacity": ""
                    "stroke": {
                      "color": "color",
                      "opacity": "",
                      "width": ""
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": "",
                    "min": ""
                  "height": null,
                  "stacked": false,
                  "stroke": {
                    "color": "#FFFFFF",
                    "opacity": 1,
                    "width": 1
                  "width": null
                "open": {
                  "x": "",
                  "y": ""
              "data": {
                "source": "Chart_Data",
                "x": "value",
                "y": "name"
              "defaultState": {
                "visible": true
              "hiddenInLegend": false,
              "label": {
                "text": "Issues"
              "line": {
                "appearance": {
                  "bullets": [
                        "fill": {
                          "color": "",
                          "opacity": ""
                        "rotation": "",
                        "stroke": {
                          "color": "",
                          "opacity": "",
                          "width": ""
                      "enabled": false,
                      "fill": {
                        "color": "",
                        "opacity": 1
                      "heatRules": {
                        "dataField": "",
                        "enabled": false,
                        "max": 100,
                        "min": 2
                      "height": 10,
                      "label": {
                        "position": {
                          "dx": 0,
                          "dy": 0
                        "text": "{value}"
                      "render": "circle",
                      "rotation": 0,
                      "stroke": {
                        "color": "",
                        "opacity": 1,
                        "width": 1
                      "tooltip": {
                        "background": {
                          "color": "",
                          "opacity": 1
                        "cornerRadius": 3,
                        "enabled": true,
                        "pointerLength": 4,
                        "text": "{name}: [bold]{valueY}[/]"
                      "width": 10
                  "connect": true,
                  "fill": {
                    "color": "",
                    "opacity": 0
                  "minDistance": 0.5,
                  "stroke": {
                    "color": "",
                    "dashArray": "",
                    "opacity": 1,
                    "width": 3
                  "tensionX": 1,
                  "tensionY": 1
                "open": {
                  "x": "",
                  "y": ""
              "name": "Issues",
              "render": "column",
              "stepLine": {
                "appearance": {
                  "bullets": [
                        "fill": {
                          "color": "",
                          "opacity": ""
                        "rotation": "",
                        "stroke": {
                          "color": "",
                          "opacity": "",
                          "width": ""
                      "enabled": true,
                      "fill": {
                        "color": "",
                        "opacity": 1
                      "heatRules": {
                        "dataField": "",
                        "enabled": false,
                        "max": 100,
                        "min": 2
                      "height": 10,
                      "label": {
                        "position": {
                          "dx": 0,
                          "dy": 0
                        "text": "{value}"
                      "render": "circle",
                      "rotation": 0,
                      "stroke": {
                        "color": "",
                        "opacity": 1,
                        "width": 1
                      "tooltip": {
                        "background": {
                          "color": "",
                          "opacity": 1
                        "cornerRadius": 3,
                        "enabled": true,
                        "pointerLength": 4,
                      "width": 10
                  "connect": true,
                  "fill": {
                    "color": "",
                    "opacity": 0
                  "minDistance": 0.5,
                  "stroke": {
                    "color": "",
                    "dashArray": "",
                    "opacity": 1,
                    "width": 3
                  "tensionX": 1,
                  "tensionY": 1
                "open": {
                  "x": "",
                  "y": ""
              "tooltip": {
                "background": {
                  "color": "",
                  "opacity": 1
                "cornerRadius": 3,
                "enabled": true,
                "pointerLength": 4,
                "text": "{name} [bold]{value}[/]"
              "visible": true,
              "xAxis": "numIssues",
              "yAxis": "Issue",
              "zIndex": 0
          "title": {
            "text": "Hello"
          "xAxes": [
              "appearance": {
                "font": {
                  "size": "",
                  "weight": 500
                "grid": {
                  "color": "",
                  "dashArray": "",
                  "minDistance": 100,
                  "opacity": 0,
                  "position": 0.5
                "inside": false,
                "labels": {
                  "color": "",
                  "horizontalCenter": "middle",
                  "opacity": 1,
                  "rotation": 0,
                  "verticalCenter": "middle"
                "opposite": false
              "category": {
                "break": {
                  "enabled": false,
                  "endCategory": "",
                  "size": 0.05,
                  "startCategory": ""
              "date": {
                "baseInterval": {
                  "count": 1,
                  "enabled": false,
                  "skipEmptyPeriods": false,
                  "timeUnit": "hour"
                "break": {
                  "enabled": false,
                  "endDate": "",
                  "size": 0.05,
                  "startDate": ""
                "format": "M/d",
                "inputFormat": "yyyy-MM-dd kk:mm:ss",
                "range": {
                  "max": "",
                  "min": "",
                  "useStrict": false
              "inversed": false,
              "label": {
                "color": "",
                "enabled": false,
                "text": "Time"
              "name": "numIssues",
              "render": "value",
              "tooltip": {
                "background": {
                  "color": "",
                  "opacity": 1
                "cornerRadius": 3,
                "enabled": true,
                "pointerLength": 4,
                "text": ""
              "value": {
                "break": {
                  "enabled": false,
                  "endValue": 100,
                  "size": 0.05,
                  "startValue": 0
                "format": "#,###.##",
                "logarithmic": false,
                "range": {
                  "max": "",
                  "min": "",
                  "useStrict": false
              "visible": true
          "yAxes": [
              "appearance": {
                "font": {
                  "size": "",
                  "weight": 700
                "grid": {
                  "color": "#ADADAD",
                  "dashArray": "",
                  "minDistance": null,
                  "opacity": 0.5,
                  "position": 0
                "inside": true,
                "labels": {
                  "color": "#FFFFFF",
                  "opacity": 1,
                  "rotation": 0,
                "opposite": false
              "category": {
                "break": {
                  "enabled": false,
                  "endCategory": "",
                  "size": 0.05,
                  "startCategory": ""
              "date": {
                "baseInterval": {
                  "count": 1,
                  "enabled": false,
                  "timeUnit": "hour"
                "break": {
                  "enabled": false,
                  "endDate": "",
                  "size": 0.05,
                  "startDate": ""
                "format": "M/d/yyyy HH:mm:ss",
                "range": {
                  "max": "",
                  "min": "",
                  "useStrict": false
              "inversed": true,
              "label": {
                "color": "#A7A7A7",
                "enabled": true,
                "text": "Test"
              "name": "Issue",
              "render": "category",
              "tooltip": {
                "background": {
                  "color": "",
                  "opacity": 1
                "cornerRadius": 3,
                "enabled": true,
                "pointerLength": 4,
                "text": ""
              "value": {
                "break": {
                  "enabled": false,
                  "endValue": 100,
                  "size": 0.05,
                  "startValue": 0
                "range": {
                  "max": "",
                  "min": "",
                  "useStrict": false
              "visible": true
        "type": "ia.chart.xy"
    "meta": {
      "name": "root"
    "props": {
      "direction": "column"
    "type": "ia.container.flex"
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "title": {
        "text": "Hello"
      "xAxes": [
          "label": {
            "enabled": false,
            "text": "Time",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "format": "M/d"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
            "grid": {
              "color": "",
              "opacity": 0,
              "dashArray": "",
              "minDistance": 100,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "name": "Issue",
          "label": {
            "enabled": true,
            "text": "Test",
            "color": "#A7A7A7"
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": true,
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": true,
            "labels": {
              "color": "#FFFFFF",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "#ADADAD",
              "opacity": 0.5,
              "dashArray": "",
              "position": 0
            "font": {
              "size": "",
              "weight": 700
      "series": [
          "name": "Issues",
          "label": {
            "text": "Issues"
          "visible": true,
          "defaultState": {
            "visible": true
          "data": {
            "x": "value",
            "y": "name"
          "yAxis": "Issue",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "{name} [bold]{value}[/]",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "column",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "#FFFFFF",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": null,
              "height": null,
                "fill": {
                  "color": "color",
                  "opacity": ""
                "stroke": {
                  "color": "color",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "text": "{name}: [bold]{valueY}[/]",
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
      "dataSources": {}
    "meta": {
    "position": {
      "basis": "400px"
    "custom": {},
    "propConfig": {
        "binding": {
          "config": {
          "type": "property"
Thanks.
I can add textShadow : 2px 2px 5px black into the CSS in my browser's development tools to get what you're looking for but I can't figure out how to add it into the XY Chart properties. I'm sure someone else will be along ...
