[XY Chart] Maximum call stack size exceeded
On an XY Chart, I've got :
  • an error saying "Maximum call stack size exceeded" :
  • no line appearing on the chart
Below is the summary code for my chart.
And the source dataset : dataset_moy_cintre_t_stamp.txt (17.5 KB)
Thanks in advance for any advice.
maximum call stack size exceeded
Summary
"type": "ia.chart.xy",
"version": 0,
"props": {
"legend": {
"position": "top"
"xAxes": [
"name": "t_stamp",
"label": {
"enabled": false,
"text": "t_stamp",
"color": ""
"visible": false,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": true,
"render": "value",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###"
"appearance": {
"opposite": false,
"inside": true,
"labels": {
"color": "",
"opacity": 1,
"rotation": 90,
"verticalCenter": "middle",
"horizontalCenter": "middle"
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 10,
"position": 0.5
"font": {
"size": 12,
"weight": 500
"yAxes": [
"name": "moy_cintre",
"label": {
"enabled": false,
"text": "Cintre Moyen",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": 0.5,
"min": -0.5,
"useStrict": false
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": null,
"position": 0.5
"font": {
"size": "",
"weight": 500
"series": [
"label": {
"visible": true,
"hiddenInLegend": false,
"defaultState": {
"visible": true
"data": {
"source": "ds0",
"x": "t_stamp",
"y": "moy_cintre"
"xAxis": "t_stamp",
"yAxis": "moy_cintre",
"zIndex": 0,
"tooltip": {
"enabled": true,
"text": "{name}: [bold]{valueY}[/]",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"render": "line",
"candlestick": {
"open": {
"x": "",
"y": ""
"high": {
"x": "",
"y": ""
"low": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"deriveFieldsFromData": {
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"column": {
"open": {
"x": "",
"y": ""
"appearance": {
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"stacked": false,
"width": null,
"height": null,
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"heatRules": {
"enabled": false,
"max": "",
"min": "",
"dataField": ""
"line": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": false,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": false,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"stepLine": {
"open": {
"x": "",
"y": ""
"appearance": {
"connect": true,
"tensionX": 1,
"tensionY": 1,
"minDistance": 0.5,
"stroke": {
"width": 3,
"opacity": 1,
"color": "",
"dashArray": ""
"fill": {
"opacity": 0,
"color": ""
"bullets": [
"enabled": true,
"render": "circle",
"width": 10,
"height": 10,
"label": {
"text": "{value}",
"position": {
"dx": 0,
"dy": 0
"fill": {
"color": "",
"opacity": 1
"stroke": {
"color": "",
"opacity": 1,
"width": 1
"rotation": 0,
"tooltip": {
"enabled": true,
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"fill": {
"color": "",
"opacity": ""
"stroke": {
"color": "",
"opacity": "",
"width": ""
"rotation": ""
"heatRules": {
"enabled": false,
"max": 100,
"min": 2,
"dataField": ""
"dataSources": {}
"meta": {
"name": "cintre_1"
"position": {
"x": 1196.43,
"y": 324.326,
"height": 202,
"width": 502.0000000000001
"custom": {},
"propConfig": {
"props.dataSources.ds0": {
"binding": {
"type": "property",
"config": {
"path": "parent.custom.OF_moyennes"
Eventually I noticed that the source dataset was too big for the XYChart.
This source dataset is the result of Named Query which returned many thousands rows : one event every minute during 3 days. However only 200 of those rows where displayed in the datasource binding on the XYChart.
To reduce the dataset length, in the Named Query, I used 2 solutions which both work :
  • only return the events every 5 min, considering that each entry will represent the average data for the last 5 minutes
(HOUR( date_impr) * 60) + (FLOOR(MINUTE(date_impr) / 5) * 5) as t_stamp
  • or only keep in "decadrages" table the events which correspond to a minute when something happens on an other table called "headtemp"
SELECT
<"items to select">
FROM decadrages
JOIN headtemp ON DATE_FORMAT(decadrages.date_impr, '%Y-%m-%d %H:%i:00')=DATE_FORMAT(headtemp.date_heure, '%Y-%m-%d %H:%i:00')
