[XY Chart] Maximum call stack size exceeded
Eventually I noticed that the source dataset was too big for the XYChart.
This source dataset is the result of Named Query which returned many thousands rows : one event every minute during 3 days. However only 200 of those rows where displayed in the datasource binding on the XYChart.
To reduce the dataset length, in the Named Query, I used 2 solutions which both work :
  • only return the events every 5 min, considering that each entry will represent the average data for the last 5 minutes
(HOUR( date_impr) * 60) + (FLOOR(MINUTE(date_impr) / 5) * 5) as t_stamp
  • or only keep in "decadrages" table the events which correspond to a minute when something happens on an other table called "headtemp"
SELECT
<"items to select">
FROM decadrages
JOIN headtemp ON DATE_FORMAT(decadrages.date_impr, '%Y-%m-%d %H:%i:00')=DATE_FORMAT(headtemp.date_heure, '%Y-%m-%d %H:%i:00')
