Thanks. I just fixed the code. I hope it's okay now.
I've copied the chart to a new view, then the issue is gone.
"type": "ia.chart.xy",
"version": 0,
"props": {
"title": {
"text": "Daily Efficiency By Machine",
"appearance": {
"font": {},
"padding": {
"bottom": 10
"legend": {
"markers": {
"width": 10,
"height": 10
"labels": {
"font": {
"size": 10
"selection": {
"enabled": true
"xAxes": [
"name": "Day",
"label": {
"enabled": false,
"text": "Day",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "date",
"category": {
"break": {
"enabled": false,
"startCategory": "",
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": true,
"timeUnit": "day",
"count": 1,
"skipEmptyPeriods": false
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy/MM/dd",
"format": "M/d"
"value": {
"range": {
"max": "",
"min": "",
"useStrict": false
"logarithmic": false,
"break": {
"enabled": false,
"startValue": 0,
"endValue": 100,
"size": 0.05
"format": "#,###.##"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"verticalCenter": "middle",
"horizontalCenter": "middle"
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 1,
"position": 0
"font": {
"size": "",
"weight": 500
"yAxes": [
"name": "Efficiency",
"label": {
"enabled": false,
"text": "Efficiency",
"color": ""
"visible": true,
"tooltip": {
"enabled": true,
"text": "",
"cornerRadius": 3,
"pointerLength": 4,
"background": {
"color": "",
"opacity": 1
"inversed": false,
"render": "value",
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05
"date": {
"baseInterval": {
"enabled": false,
"timeUnit": "hour",
"count": 1,
"range": {
"max": "",
"min": "",
"useStrict": false
"break": {
"enabled": false,
"startDate": "",
"endDate": "",
"size": 0.05
"inputFormat": "yyyy-MM-dd kk:mm:ss",
"format": "M/d/yyyy HH:mm:ss"
"value": {
"range": {
"max": 1.2,
"min": 0,
"useStrict": true
"break": {
"enabled": false,
"startValue": 100,
"endValue": 110,
"size": 5
"format": "###.##%"
"appearance": {
"opposite": false,
"inside": false,
"labels": {
"color": "",
"opacity": 1,
"rotation": 0,
"grid": {
"color": "",
"opacity": 1,
"dashArray": "",
"minDistance": 20,
"position": 0
"font": {
"size": "",
"weight": 500
"appearance": {
"font": {
"size": "",
"weight": 500
"grid": {
"color": "",
"dashArray": "",
"minDistance": 0,
"opacity": 0,
"position": 0
"inside": true,
"labels": {
"color": "",
"horizontalCenter": "middle",
"opacity": 1,
"rotation": 0,
"opposite": true
"category": {
"break": {
"enabled": false,
"endCategory": "",
"size": 0.05,
"startCategory": ""
"date": {
"baseInterval": {
"count": 1,
"enabled": false,
"skipEmptyPeriods": false,
"timeUnit": "hour"
"break": {
"enabled": false,
"endDate": "",
"size": 0.05,
"startDate": ""
"format": "M/d/yyyy HH:mm:ss",
"range": {
"max": "",
"min": "",
"useStrict": false
"inversed": false,
"label": {
"color": "",
"enabled": true,
"text": ""
"name": "ManPower",
"render": "value",
"tooltip": {
"background": {
"color": "",
"opacity": 1
"cornerRadius": 3,
"enabled": true,
"pointerLength": 4,
"text": ""
"value": {
"break": {
"enabled": false,
"endValue": 100,
"size": 0.05,
"startValue": 0
"format": "#,###.##",
"range": {
"max": 1.2,
"min": 0,
"useStrict": false
"visible": false
"dataSources": {
"ShiftC": []
"meta": {
"name": "XYChart"
"position": {
"x": 192.5,
"y": 179,
"height": 375,
"width": 435,
"grow": 1
"custom": {},
"propConfig": {
"props.dataSources.ShiftA": {
"persistent": false
"props.dataSources.ShiftB": {
"persistent": false
"props.dataSources.ShiftC": {
"persistent": true
"props.dataSources.Total": {
"persistent": false
"props.style.fontSize": {
"binding": {
"type": "property",
"config": {
"path": "view.params.width"
"transforms": [
"code": "\twidth = self.session.custom.width\n\tif value < width:\n\t\treturn 10\n\telse:\n\t\treturn ''",
"type": "script"
"persistent": true
"props.title.appearance.font.size": {
"binding": {
"type": "property",
"config": {
"path": "this.props.style.fontSize"
